Yeah, great info, thanks for posting.
e46 M3 suspension setup, or how to not downgrade your car with suspension mods
Nice read, always learning!2004 Silbergrau Metallic 6MT
I know what you’re getting at here but I think bullet point 1 and 4 contradict each other. There is a trade off between stiffness and camber of the outer tire. Another consideration, car with unbalanced front to rear roll stiffness and soft stock sways will have less maximum grip than a car with stiffer aftermarket sways if the car has better matched F&R roll stiffness.Originally posted by ObiobanPreface
So, generally...
-the stickier your tires are, the more roll stiffness you need
-the less suspension travel you have, the more stiffness you need
-the higher (stiffer) the frequency is, the less grip you have
-the stiffer the sways, the less grip
Also, stiffness is not as much of a factor on a smooth road.
I think a good takeaway for everyone is that this is very complicated and easy to get the system out of wack when you start changing things.
Hmm, I worded that poorly. I way trying to convey that the stiffer the springs and/or sways are, the less grip you'll get from a given tire. Completely agreed that a stickier tires on a stiffer setup often results in more grip than a less sticky tire on a softer setup. Let me work on rewording that to be clearer...Originally posted by T.J. View Post
Fantastic thread! I know setups can vary wildly depending on other suspension/weight modifications. However, for those of us running a mostly stock setup, it would be great to know some general recommendations (spring rates, dampers, ride height, sway bars, etc) to cut through the complexity.Last edited by mcfreid; 04-10-2020, 06:13 AM.2006 M3 ZCP coupe, jet black on black, 6 speed
2001 325xi wagon, red on beige, 5 speed
Couple disclaimers:Originally posted by mcfreid View PostFantastic thread! I know setups can vary wildly depending on other suspension/weight modifications. However, for those of us running a mostly stock setup, it would be great to know some general recommendations (spring rates, dampers, ride height, sway bars, etc) to cut through the complexity.
1) you should really run the numbers! It doesn't take that long and it's amazing how quickly small changes DO make your car different. There's a reason BMW used so many different spring combinations, depending on how your car was optioned.
2) I'm going to suggest a flat ride setup, which some people are on board with and some are not. I very intentionally avoided flat ride in the original post, to keep everything uncontroversial. I've been running flat ride for while on all my cars, and am hugely on board with it at this point.
That said, for a very close to stock car, this would likely be pretty stellar:
TCK SAs
300 lbs front springs, 700 lb rear springs
Turner front sway (with turner sealed adjustable end links)
stock rear sway
If street only: e36 strut hats
If also track: Camber plates (I like the turner hybrids) and adjustable rear control arms
-possibly also swap out front sway for GC Race sway (unsealed end links will get noisy over time on GC's) and swap stock rear sway for CSL rear sway
- Likes 2
Hey Ian,
you have extensive knowledge with turner hybrid camber plates with ohlins dfv. I currently have ohlins with a csl rear bar and a hotchkis front on medium stiff. Car feels great but I want to experiment with flatride. If I got the turner hybrid camberplates 3ddm front strut spacer and 8inch 350 front 60mm springs would that be a good start? With the front strut spacer and the tuner plates I shouldn’t have any droop issues correct?
Which kingpins do you have installed?Originally posted by Grke46m3 View PostHey Ian,
If it feels great why mess with it? Does it have an uncomfortable pitching motion?Originally posted by Grke46m3 View PostHey Ian,
More comfortable, faster, easier to drive at the limit...Originally posted by T.J. View Post
I've been running the Vogtland 7.5" springs. That lets me get the ride height adjuster higher, for the same ride height, so I can fit the tire under the adjuster instead of next to it. They have just enough travel to cover the Ohlins travel.Originally posted by Grke46m3 View PostHey Ian,
The turner hybrids will work nicely with the 3DM front strut spacers-- should address the bump issue entirely.
What's the flat ride ratio with the 350 fronts? going off intuition, it feels like that might not be enough to get you into the flat ride range (assuming you're keeping the stock 628 rears).
Vogtland also sells 325s, which is what I'm running on the passenger front side of my car (and the passenger rear is a stock Ohlins 628).
... I suspect you're going to want to go back to the M3 stock rear sway (instead of the CSL sway). But, again, I haven't run the numbers for your car, so just guesstimating.
