    I should have said that it'll depend on strut. I have MCS and can run anything I want, bottom perch height-wise - plenty of adjustment. On my Bilstein b6 with GC conversion, 7" was 325lb so at 400lb, I would look for 6.25" like tck vvs or a 6" with extended travel like eibach's xt.
    I run tck 400lb which is only in 60mm & it says 6.5" but really is 6.25" tall.
      IMO, using stock mounts defeats a very useful feature of aftermarket coilovers/plates for us - reducing ride height for free through reduction of stack height in camber plates from GC, Vorshlag, TMS and probably others.
      If you just want stock like height (14"+) then you'll have plenty of travel I suppose.
      There's a caveat on this with the Ohlins, isn't there? Hence the need for those 3DM spacers when you shorten the stack height with aftermarket camber plates. I was always under the impression that the R&T struts were designed specifically for stock top mounts, leading to the ride height issues without the strut spacers.
        Ah ok. I'm not up to speed on the ohlins and that spacer issue. I want as much travel as possible at a pretty low height of like 13.25" so maybe someone like me wouldn't even bother with the spacer.
        Is the concern, without a spacer, that the car would sit too low with aftermarket plates?
        Couldn't you just move the bottom perch upwards to compensate? Droop will be very short, I imagine.
          The strut spacer is the result of the setup being developed with european kingpins and US kingpins being different.
            The problem is that the Ohlins have very little total travel-- so to have them function properly, you pretty much MUST optimize ride height for bump/droop travel.
            Without the strut spacers on a US spec car, you have to be lower than the suspension geometry is good for. Similarly any camber plate that increases bump travel too much does the same.
              Ok so then it does seem that they engineered them for the taller/thicker stock mounts :/
              Too bad stock mounts are as expensive as camber plates these days!
                Euro and US m3s use the same kingpins.
                  Hmm, seems like you’re right.
                  well, something is different and I forget what, it seems. Whatever it is, the result is that the US cars need the strut spacer and the euro cars don’t.
                    Yeah weird, Euro car here and with ohlins and GC street camber plates I sit at about 13.25" hub to fender with the right bump/droop without the use of the spacer. When using the spacer it put me further outside of the range. Not sure what else would be different in the geometry though.
                      Is this true for US cars regardless whether it's using stock top hats or camber plates?
                        For those on a budget, my current setup according to the calculator and butt dyno is flat ride.
                        Bilstein B4
                        Eibach pro kit springs
                        Hotchkis F/R sways medium front, soft rear
                        Great comfort, bumps even with Hankook v12 (awful sidewalls) feel smooth, car turns in very well, and isnt unsettled at motion changes/apex bumps. Couldnt be happier, as it nearly feels my like old MCS setup. Ride height is fixed, but low enough where it looks OE+ but not low enough where its compromising the control arms/bushings.
                          I went with a build directly built by FCM.
                          H&R street coilvers
                          450lb 6" f spring
                          800lbs 6" r spring
                          GC weighted jacks
                          GC front Sway bar stiffest setting
                          OE rear sway bar.
                          Will give some feed back as soon I get everything in and on the car.
                            Bilstein B4
                            What are you spring rates? Also, did you measure corner weights?
                            H&R street coilvers
                            450lb 6" f spring
                            800lbs 6" r spring
                            GC weighted jacks
                            OE rear sway bar.
                            Also curious if you measured your corner weights before FCM recommended spring rates? Were these spring rates aimed towards a sporty or more race focused setup?
                            2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 288/280 Schrick Cams+DLC Followers | Lang Head | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 400/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | Turbo Toys V2 Hub | WPC Rod Bearings
                              H&R street coilvers
                              450lb 6" f spring
                              800lbs 6" r spring
                              GC weighted jacks
                              OE rear sway bar.
                              With those rates it sounds borderline pitchy, and adding GC on full stiff to those front rates sounds very understeery...
                              Did FCM suggest these rates/bar settings? Are you running heavy aero/splitter to counter?
                              Youtube DIYs and more
                                Per the spreadsheet, those spring rates give you a 1% flat ride.
