My previous suspension was TCK SA and after talking with TC he recommended 400F/500R spring rates. Any idea why the spring rates are so much different than flat rides approach?
Originally posted by Cronenberged View PostYes recommended by FCM, based on corner weights and dual use. Don't have have aero yet, but eventually.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Per the spreadsheet, those spring rates give you a 1% flat ride.
Youtube DIYs and more
Originally posted by mrgizmo04 View PostYeah that's set up for "flat" ride at like 300mph with those frequencies...
Sent from my SM-G950U using Tapatalk2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Is the approach to aim between a 45-70 mph flat ride?
What are your FRC and hz ratio per FCM setup recommendations?
Had me searching deep for the pic.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Originally posted by mrgizmo04 View PostI guess I can see it if your car is rather stripped where you are carrying closer to 55-60% of weight in the front.
Yeah with weight loss (mostly at the rear), those rates make more sense and result in some flat ride. Just getting readout of the rates without additional context seemed sacrilegious from FCM suggesting borderline pitchy setup, so ok there.
The only thing I'm still hung up on is adding so much front bar to those front rates, seems like a pushy setup with FRC over 80? Is that just driver preference, or some other context missing?
GC front bar comes in 3 different wall thicknesses and is adjustable.
Originally posted by Obioban View PostGC front bar comes in 3 different wall thicknesses and is adjustable.2008 E90 M3 6MT
2011 E90 328i 6MT
RWD, slicktop, no iDrive
What are you spring rates? Also, did you measure corner weights?
Also curious if you measured your corner weights before FCM recommended spring rates? Were these spring rates aimed towards a sporty or more race focused setup?
The point of the setup is budget flat ride. I wasn’t interested in spending $5,000+ to get a proper setup damper and spring rate conversion. Not saying it’s not worth it, but for how I drive my 46, the cost doesn’t add any more experience to the car.
My s2000 on the other hand I’ll be working with Shaik on dialing that in as it’s already purpose build to see track time.
