Engine Cycle Suggestions - Emissions Rejected
    Originally posted by martin.oconnor View Post
    I used this approach a few days ago and it succeeded in getting my catalyst and heated-catalyst tests into readiness.
    (Driving at 55mph in the slow lane was a revelation. There appears to be a large class of people who actually do it full time.)
    Still having issues with evaporation and secondary air tests, but that is another story.
    SAP will only go ready on a cold start. EVAP had to be less than 3/4 tank to go ready.
    I wes able to pass in MD without EVAP going ready.
      Yup - my tank was 100% full so the preconditions for that test were not met.
      In CA, all modules have to be in the ready state to pass.
        Evap is not needed to pass in CA, just fyi.
          https://www.bar.ca.gov/Industry/OBD_...ence#readiness
          Ah - I thought it was all of them in CA. Good to know. (Now just need to sort the secondary air, which has not reset despite multiple cold starts. I've had some related pending codes in the recent past so might need a new secondary air pump.)
            I also believe EGT was removed or ignored by smog computers several years ago.
              Originally posted by sdmcoupe View Post
              I tried numerous drive cycles w/o success. I was running out of time so was looking at all options. I tried a product called "Cataclean". I wasn't expecting it to work but after pouring it in with a 1/4 tank of gas left and a short drive, my CAT monitor set itself to OK. Took the car in and it passed smog w/o issue. So relieved.
              My car has 79k so I was confident i wasn't having an issue with actual catalytic converter.
              I know this is a necro (sorry) but I wanted to thank you for this. After multiple drive cycles at 3am my stubborn CAT monitor only set to 'ready' after the cataclean. I was about to pay $200 for a smog repair shop to go through the drive cycle themselves on their own dyno to make it ready. $200 is a lot of chicken nuggets, so again, thank you! 141k stock M3 for reference.
