Adjustable Rear Camber Arms
No experience with either of them, but the Ground Control arms have all of their adjustment at the outer ends, and also use monoballs.
I couldn't find where anybody had verified the Ground Control bearing manufacturer, so I went with the Turner arms (with bushings) that also adjust at the outer ends, to replace the TC Kline arms currently on my car.2003 Imola Red M3 w/ SMG
The GCs are steel rather than aluminum and Turner is backordered till August.Originally posted by K-Dawg View PostNo experience with either of them, but the Ground Control arms have all of their adjustment at the outer ends, and also use monoballs.
Youtube DIYs and more
Those are brand new? Yikes.Originally posted by mrgizmo04 View Post'03.5 M3 SMG Coupe - Jet Black / Black
I’m running GC. No issues and easy to adjust.
Edit: I emailed Forest at GC and asked what bearings (April 2020). His response was they use Lemforder and Delphi for their ARCAs, for whatever that is worth.Last edited by oceansize; 04-14-2021, 04:37 PM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I would trust Bimmerworld stuff. The stock arms suck. There is barely any room for adjustment. The exhaust is not in the way during an alignment. The adjustments are at the wheel for camber. Toe is just moving the spindle where it bolts to the body. You'll need a pry bar for that.This is my Unbuild Journal and why we need an oil thread
Unfortunately, not on the BWs. One of the jamb nuts is right above the exhaust. I'd like to know if it is possible to get at that while getting an alignment. BW says that it is, but most of their track cars have a single pipe section 2 and that allows for a bit more space to adjust.Originally posted by Arith2 View PostI would trust Bimmerworld stuff. The stock arms suck. There is barely any room for adjustment. The exhaust is not in the way during an alignment. The adjustments are at the wheel for camber. Toe is just moving the spindle where it bolts to the body. You'll need a pry bar for that.
Towards the end of this video (1:07:00 or so), there's a couple decent shots of how the assembled rear end looks with eibach camber arms. I know you specifically asked about bimmerworld, but the eibach arms look like they have a jamb nut that's located even further into the subframe than the bimmerworld ones. I have no idea how you would get a wrench onto that nut, even with the exhaust removed.Originally posted by Slideways View PostI'm also trying to understand how difficult it is to adjust camber with the stock exhaust in place.
Maybe the idea is to loosen the jamb nut closest to the wheel, then loosen the center section of the arms and then turn the inner jamb nut by hand (which should have no torque on it at that point).Last edited by heinzboehmer; 04-14-2021, 11:10 PM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Maybe thatThis is my Unbuild Journal and why we need an oil thread
If I recall, Obioban said that they are adjustable with the stock section 2, but maybe he can elaborate on how he accesses the upper jamb nut.Originally posted by repoman89 View PostBump. Did you end up with the Bimmerworld arms? I want to put them on my car for this upcoming year because my stock arms maxed out at around -1.3 degrees. Also running stock section 2 and muffler and don't want to have to remove all that for an alignment.
BTW, the ball joints used on the BW arms are Febi (Bilstein), so an OEM manufacturer which is nice.
Awesome, thanks for the reply. I am sold. The bearing was my other concern!Originally posted by Slideways View Post
