Interest in: 1:1 CSL 1 Piece Forged Wheels
    19 x 9 +37
    19 x 10 +25
    D-O
    Old, not obsolete.
      9" et30 arc8s are already too sunken in. Where'd you come up with et37?
      People are just throwing random widths/offsets at the wall.
        Haha I always enjoy threads like this.
          The specs D-O posted are exactly the specs that RAC used. Perfect fit, and probably drives better than stancenation.
          2003 Imola Red M3 w/ SMG
            So 9"et30 is stance nation huh?
              Totally agree on the perfect fit.
              https://web.archive.org/web/20070401...d.php?t=150568
                Another data point, I'm running ARC-8 at 19x9 et28 up front and only 2.0 degrees camber (and really could do less camber), no rub at full lock. Which is to say I'm not sure that et37 is "perfect" or that et28 is stance nation.
                  The 18" can be done and scale down the design. Knurled bead will be an option as well.
                  Working to complete a few preliminary steps to begin prototypes machining.
                    Hopefully these new wheels will be specifically designed based on E46 M3 lug bolt specs which the RAC wheels were:
                    Pulled from the RAC GB thread:
                    The wheel Lug Bolts on the E46 M3 have these specs:
                    a) A 17 mm hex head design used to tighten or remove the bolt
                    b) A 'cone seat' type collar to secure the wheel to the hub properly
                    c) It must have the same bolt diameter sizing as the OEM lug bolt (12mm)
                    d) It must have the same thread pitch as the OEM lug bolt (1.5)
                    e) The thread length on the the stock OEM lug bolts is exactly 24mm*
                    *There is some wiggle room on this spec, but only about 1 mm for trouble free operation. Any more than that could cause problems.
                    Threads should engage at least 6 full turns into the hub. If the thread length is too long: it will interfere with the parking brake mechanism and or wheel speed sensors on the car. If the thread length is too short: the wheel will not be secured to the hub properly, and could result in the loss of a wheel while driving. (worst case scenario)
                      If I recall correctly, people were running a 10mm spacer up front and a 12mm spacer in the rear
                      Formally SWRTstang_M3 on M3forum.net with a join date of 07/2004
                        In for 18s as well
                          Correct on fit.
                          Old, not obsolete.
                            No spacers with my RAC wheels. They clear the 996 calipers and I am very happy with the fit.
                            D-O
                            Old, not obsolete.
                              Following for 19's
                                Moved tangential posts as requested.
                                2008 E90 M3 6MT
                                2011 E90 328i 6MT
                                RWD, slicktop, no iDrive
