Turbo builds
I have a BW sxe369 (69/73 in precision terms) coming in. Was going to part out the kit and do a different build, but that would mean deleting the ac and a bunch of other things making it not street friendly. I also ordered FIC 2150cc injectors. Hoping to have the car running soon
That's good data and refreshing to hear.
What size turbo were you running? How large is your exhaust turbine side?
Originally posted by Mspir3d View Post
I run the stock exhaust with an electronic cutout. I don’t think your exhaust is the problem especially at that level of pressure. I ran 20 psi on the dyno last week with the cutout closed. When I had problems building boost, it was because there was a big crack in my intake manifold.
Curious, when you first installed your max psi turbo kit, what exhaust did you have installed? i'm having any issue where i cant find a boost leak and my turbo wont hit 10psi only 9 and then trails to 4psi by 8k rpms. people are telling my my exhaust is too restrictive and creating too much back pressure or that my turbo is too small and that the S54 is asking for air up top than my turbo can give.
ive replaced my cheap ebay BOV and Wg with authentic Tial Q 50mm and turbosmart wg45 hypergate units and had no change in my boost issue so im trying to figure out something else.
ive been trying to find someone selling a maximum psi intake manifold for sale to replace the ebay one i have currently.
Originally posted by Mspir3d View Post.025 would probably be fine for 10 psi. You can always regap them if you get spark blowout.
Just wondering if anyone has thought to try comp turbo oil-less turbos in the past. They are big in the 370z car scene. A shot of grease each oil change every 3000 miles. Works great, and quick to build boost. From what I’ve researched it’s almost a no brainer to go that route and have an easier install.
so you suggest .022? is that specific to a range of power of PSI one will be running or is it just a value thats been confirmed to work well in forced induction overall? i will be running 10PSI and was curious if i should do .025 or .022 as you mentioned
Originally posted by Nicholas1996 View Post
.022”
Jesus. Haha I’ll definitely look into them. I can only imagine mine are screaming and about to snap. Had a mishap with the car on Sunday. Bimmerworld Vanos line started leaking after 2k miles. Not exactly
exciting. But bimmerworld took care of it thankfully!
Originally posted by Mspir3d View PostThe box I have says dcpr9e. I think the plugs that are in now are gapped at .020 and the plugs going in I gapped down to .018. I tend to go through a decent amount of plugs but they’re super cheap at advance auto parts with the 15% off. If you’re not running a lot of pressure, a larger gap is better.
The box I have says dcpr9e. I think the plugs that are in now are gapped at .020 and the plugs going in I gapped down to .018. I tend to go through a decent amount of plugs but they’re super cheap at advance auto parts with the 15% off. If you’re not running a lot of pressure, a larger gap is better.Last edited by Mspir3d; 10-07-2020, 04:22 PM.
thanks for the advice, got it done.
curious about your spark plug setup, i have a set of NGK DCPR9EKP plugs and was curious what gap you used with your plugs, did you also use 9 series plugs?
Originally posted by Mspir3d View PostMine has been in there for 5 years now and hasn't had a problem. The pipe dope has worked well for me.
curious about your spark plug setup, i have a set of NGK DCPR9EKP plugs and was curious what gap you used with your plugs, did you also use 9 series plugs?Last edited by nextelbuddy; 10-07-2020, 12:12 PM.
Originally posted by Mspir3d View PostI ordered a set of these:
https://www.seemslegitgarage.com/pro...d-stub-upgrade
They are great axles but maybe a warning would have been nice. The bolts on the cv joint by the wheel don't clear the upper control arm when the suspension is loaded. I contacted the company and it's normal and they need to "self clearance" 😂. So after some terrible noises especially going over bumps, they have cut a groove into my upper control arms and are no longer making noise...They appear to be very strong axles though. Other than the clearance problem, I have no complaints.
exciting. But bimmerworld took care of it thankfully!Last edited by Nicholas1996; 10-06-2020, 10:48 AM.
