Originally posted by Nicholas1996
Turbo builds
so you suggest .022? is that specific to a range of power of PSI one will be running or is it just a value thats been confirmed to work well in forced induction overall? i will be running 10PSI and was curious if i should do .025 or .022 as you mentioned
Just wondering if anyone has thought to try comp turbo oil-less turbos in the past. They are big in the 370z car scene. A shot of grease each oil change every 3000 miles. Works great, and quick to build boost. From what I’ve researched it’s almost a no brainer to go that route and have an easier install.
Originally posted by Mspir3d View Post.025 would probably be fine for 10 psi. You can always regap them if you get spark blowout.
ive replaced my cheap ebay BOV and Wg with authentic Tial Q 50mm and turbosmart wg45 hypergate units and had no change in my boost issue so im trying to figure out something else.
ive been trying to find someone selling a maximum psi intake manifold for sale to replace the ebay one i have currently.
Curious, when you first installed your max psi turbo kit, what exhaust did you have installed? i'm having any issue where i cant find a boost leak and my turbo wont hit 10psi only 9 and then trails to 4psi by 8k rpms. people are telling my my exhaust is too restrictive and creating too much back pressure or that my turbo is too small and that the S54 is asking for air up top than my turbo can give.
I run the stock exhaust with an electronic cutout. I don’t think your exhaust is the problem especially at that level of pressure. I ran 20 psi on the dyno last week with the cutout closed. When I had problems building boost, it was because there was a big crack in my intake manifold.
What size turbo were you running? How large is your exhaust turbine side?
That's good data and refreshing to hear.
Originally posted by Boost View PostMore boost. How are your builds going?
- custom top mount manifold (retains AC)
- Precision 6870 (with t51r mod)
- Radium fuel system
- ID1700’s
- built motor
- built/ported head
- syvecs ecu
- 3.5” titanium straight pipe exhaust
- OS giken LSD with 3.15 gears
Dynoed 840 sae at 25 psi last year but lost a piston at the ice cream cruise from a wrist pin retaining clip coming loose. I probably squeezed it a little too hard when I was putting it together. Im currently putting together a new engine but with selling my house and working oncology, I haven’t had time to assemble it. Changes for this year are
leaving stock dme for proefi
1000 cc ID -> 1700 ID injectors
Engine girdle
I’m still running the 72 mm XonaRotor from last year. The goal is 1100 once it’s back together but it might require some changes with the fuel pumps.
Originally posted by Mspir3d View PostDynoed 840 sae at 25 psi last year but lost a piston at the ice cream cruise from a wrist pin retaining clip coming loose. I probably squeezed it a little too hard when I was putting it together. Im currently putting together a new engine but with selling my house and working oncology, I haven’t had time to assemble it. Changes for this year are
Engine girdle
Originally posted by Cglhut View PostHoping to have mine wrapped up here soon! Here is my build:
- ID1700’s
- built motor
- built/ported head
- syvecs ecu
Any updates gentlemen? Appreciate any video inspiration from the turbo crowd
skip to 17:23 for boost noises!
4 PhotosLast edited by Mspir3d; 07-31-2022, 07:53 AM.
