Zzyzx85's '03 High Mileage Daily Driver
    Awesome build! Loving the high mileage machine that’s getting real use.
    Where did you get the replacement hoses for the ICV? I looked for bmw parts, but they don’t seem to be available. I’m assuming any PCV or vacuum line is likely fine given it’s the right size? Thanks!
      Thanks!
      I bought the hose pieces from Turner/ECS. I suppose that as long as they're the right size, PCV hose will work.
      2007 GX470
      build/journal
      ig: @zzyzx85
        I took this video of a short, quick pull a while back but I think it's worth posting it here.
        2007 GX470
        build/journal
        ig: @zzyzx85
          Inching closer to 280k.
          Recently did an oil change. I think there's about 7500 miles on it, including a track day.
          Sent off a sample to Blackstone so I'm curious to see how it is.
          2007 GX470
          build/journal
          ig: @zzyzx85
            I got my UOA back from Blackstone the other day. It reads kind of scary but their interpretation is accurate on how I'm driving the car harder nowadays. Not sure where the brass/copper is from (valve guides?) But I think the iron is from the camshaft wear I noticed.
            2007 GX470
            build/journal
            ig: @zzyzx85
              I don't know...with low lead count and high copper and trending higher iron, it may be time for a rod bearing job? You may have already gone through the lead layer (thus low lead count) and working past the copper layer (high copper count) and even into the steel shell (high iron count)? When was the last rod bearing changed? That would be my conclusion.
                Yeah copper is usually attributed to rod bearings. Doesn't really mean much without a clear trend though.
                  Rod bearings were changed out about 80k miles ago at around 200k.
                  I'm leaning towards looking for a trend before I make any moves. The weird thing was there was always copper in the oil samples I've given. The first sample was after I bought the car. The second sample was after I changed out the rod bearings.
                  2007 GX470
                  build/journal
                  ig: @zzyzx85
                    Just before Christmas, I sent the (presumed OE) first set of injectors out to RC Fuel Injection for cleaning and flow testing. Got back from vacation to find the package of freshly cleaned and flow tested injectors waiting for me like a late Christmas present.
                    I was also waiting to see how bad the injectors were lol.
                    Seeing that injector 4 was nearly 100cc lower than spec, I wasn't disappointed lol. That was amazing. I'm betting these were the OE that came with the car, so about ~260k miles on them.
                    Click image for larger version  Name:	 Views:	0 Size:	58.9 KB ID:	198844
                    2007 GX470
                    build/journal
                    ig: @zzyzx85
                      Oh yeah, forgot I had these too
                      Bought them during the Black Friday sale, while waiting in the Madrid airport for our flight back from Spain. I jokingly asked if I could pick them up on the way (they were actually a 5.5 hours drive away from Madrid).
                      Click image for larger version  Name:	20230103_211628.jpg Views:	0 Size:	139.5 KB ID:	199019
                      Click image for larger version  Name:	20230103_211530.jpg Views:	0 Size:	220.4 KB ID:	199017Click image for larger version  Name:	20230103_211554.jpg Views:	0 Size:	209.0 KB ID:	199018
                      2007 GX470
                      build/journal
                      ig: @zzyzx85
                        Finally installed the (pricey) badge on the engine cover.
                        Click image for larger version  Name:	20230129_125450.jpg Views:	0 Size:	231.9 KB ID:	203079
                        I'm leaning towards leaving off the Karbonius cf strut brace as the 3 piece OE brace is much more convenient for working under the hood.
                        I've been thinking of either cleaning/dressing up the current bar or buying a fresh new one.​
                        2007 GX470
                        build/journal
                        ig: @zzyzx85
                          My least favorite part of having an aftermarket strut brace. Will have to remove it just to apply the bmw motorsport decal, myself.
                            ​​​Seeing the pitting and wear, and the tapping, maybe it's time to change out my cams and followers. Pretty sure a follower went flat after my last track day.
                            2007 GX470
                            build/journal
                            ig: @zzyzx85
                              Yeah it's time. I just changed mine at 239k miles and one of the followers was flat as hell. No more tapping now.
                              Instagram: @logicalconclusion
                                Going to do a valve adjustment just to see if it makes a difference. It's been a while so maybe i'll give that a shot before I go in to camshaft surgery.
                                Picked up a new Interstate H7 AGM battery. I got tired of having to jump the car every Monday morning. i think the extreme heat and cold in the high desert ruins batteries. I got just over 2 years out of the current battery.
                                2007 GX470
                                build/journal
                                ig: @zzyzx85
