Tyler's 04 slicktop 6spd Silvergrey MCS/Brembo/CSL/Karbonius/Nogaros/Supersprint
    When the last Supersprint groupbuy started up, I contemplated the idea of getting the best cats (HJS) so that I would no longer have to swap headers/sect 1 every 2 years for CA SMOG. I also contemplated just having some cheap cats welded into my straight pipes, but I wanted top quality and HJS cats barely lose any power. The retail price of the HJS is eye watering, but the GB discount was hefty enough, I pulled the trigger.
    Despite the groupbuy taking a while, and issues with QC both in the manufacture and shipping of items, mine arrived in perfect condition, just in time for me to swap them in for my smog test that was due in a few weeks.
    Beauts
    Car up - I had noticed the giubo (OE, replaced in 2014-40k ago) had some new cracks forming, so I bought a new one (FCP warranty) ahead of time since you have to drop sect 1/2 to access D/S.
    SS "S" pipes out
    One of my other goals on this job, was to extend my muffler out a it more, especially (mostly) on the right side, to even the tips out. You can see how uneven it was, below. Yes, my tips are adjustable, but the factory metal piping that my tips attach to, are very short and there's no more room for me to bring the tips out further. (Only an issue with CSL diffuser)
    Next, dropped v-brace and sect 2
    Need to drop heatshield in order to reach CSB. Have to loosen CSB to push D/S back enough to get giubo out. You can access giubo without dropping sect 2 and heatshield, but then you're stuck.
    You can see cracks on the giubo. Made it almost 40k of hard driving.
    Click image for larger version  Name:	silvergHJSgiubo06.JPG Views:	0 Size:	73.3 KB ID:	147807
    Giubo removed. Inspected the shift linkage. I had done it all recently enough, though, so still well lubed and everything looking as it should. (pictured is UUC DSSR & RE tranny bushes)
    Click image for larger version  Name:	silvergHJSgiubo07.JPG Views:	0 Size:	77.6 KB ID:	147806
    40k giubo vs. new. You can buy the cheaper Febi brand, and in the package will be a factory SGF. Save yourself like $100. (also pictured is a factory corteco centering bush that wasn't actually needed [don't waste your time/$])
    Click image for larger version  Name:	silvergHJSgiubo08.JPG Views:	0 Size:	130.9 KB ID:	147808
    Don't forget to push the CSB forward when torqueing, before you finish up.
    Click image for larger version  Name:	silvergHJSgiubo09.JPG Views:	0 Size:	115.6 KB ID:	147809
    Put copper paste on the new SS hardware and the O2s. O2s (post-cat) were replaced like 7 years ago for when I was passing smog with the euro headers/cat setup. Didn't use them with my v1s, so these are still pretty new.
    Click image for larger version  Name:	silvergHJSgiubo10.JPG Views:	0 Size:	54.2 KB ID:	147810
    New pipes ready to go in:
    Click image for larger version  Name:	silvergHJSgiubo11.JPG Views:	0 Size:	172.9 KB ID:	147813
    New gaskets:
    Click image for larger version  Name:	silvergHJSgiubo12.JPG Views:	0 Size:	82.4 KB ID:	147811
    Before installing the sect 1, I routed the O2 plugs through a hole in the heatshield (made when I had euro cats) and run along the tunnel, driver side
    Click image for larger version  Name:	silvergHJSgiubo13.JPG Views:	0 Size:	101.1 KB ID:	147812
    Hello
    Click image for larger version  Name:	silvergHJSgiubo14.JPG Views:	0 Size:	179.2 KB ID:	147815
    Once the pipes are installed, I pulled the O2 plus as far forward as possible, to meet the harnesses that need to be run behind the airbox and down tranny/clutch line area (already done in 2014). They'll reach a bit past the tranny brace. It's actually a good area for them to meet the harnesses as there are already some clips for the wiring of the tranny sensors.
    Click image for larger version  Name:	silvergHJSgiubo15.JPG Views:	0 Size:	39.4 KB ID:	147814
    Before removal, I had marked (sharpie) where the S pipes settle on the header outlets. I wanted to install the new pipes about 3/16-1/4" further back:
    Click image for larger version  Name:	silvergHJSgiubo16.JPG Views:	0 Size:	145.7 KB ID:	147816
    I also shimmed the passenger side hanger with some rubber blocks. This helped push this side out a little more.
    Here's the end result:
    For me, this is perfect. While I miss having some more exhaust noise sometimes, I don't think I'll touch this setup now that I have it exactly how I want. I'll put a muffler on my other M3 to enjoy those sounds.
    In the wild:
    Impressions: Shit, the cats eliminated all the drone and rasp 😭 Bright side - the airbox is even "louder." Power-wise, I've always noticed an increase in responsiveness when going catless, then a bit less when I would swap back. I have to say, these HJS are incredible. No perceivable loss at all, and zero smell, I mean zero. Seems like even less than stock, from memory.
    Overall, the engine/exhaust sound is a little too calm for my tastes (I like a little drone and overall raspy nature). The airbox is the shining star, and that makes up for it.
    in a perfect world, I'd have an electronically controlled "dump" installed at the end of sect 2, and open it up as desired. Maybe one day.
    Next up is swapping the airbox back to stock, stock tune, and getting a smog test. We'll see if the cat/o2 monitors go green
      Holy smokes, your attention to detail, process, and sophisticated taste is inspiring. I thought I was OCD about my car, but I'm like a fat kid ( cause I am ) who plays Sunday football in the park compared to you . . . 250 LBS NFL Linebacker. And as you know, I have already stolen some of your ideas, like the Sportline wheels But, I still have so many questions, mostly related to the actual wrenching, as I am always so nervous I'll mess up 5 things to work on one This is my favorite thread, thank you for all the hard work and effort!
        Ha thanks! I guess it just comes naturally because I've always done this sort of stuff since I was a little kid. But that doesn't mean you can't learn! Almost all mistakes can be fixed too. I'm also spoiled by having 2 garages, lots of tools, time, desire, etc... Oh and covid cash / trump/biden bucks I shouldn't have gotten 😂
          Cleanest stock muffler I have ever seen hands down!
          Nice update bro.
          2005 BMW ///M3
            CA Smog time
            As you saw, I put quality cats into sect 1, partly for smell, but mostly so that the car would be pretty smog ready at any given time. Now all I have to do is swap out the airbox and ECU tune, and I'm ready to test after.
            Unfortunately, the entire strut bar must be removed, so keep the car on the ground and fixed so that alignment (camber) isn't lost. Though, I did mark my camber on my towers since I just got an alignment.
            Airbox off
            Looks stock to meeeee
            After stock tune, I'm able to get monitors to pass pretty quickly. The HJS cats ain't slackin.
            Passed with ease. My guy does a quick look in the engine bay, makes sure I've used my scanner to confirm readiness so we don't waste each other's time, and he's done in 5 minutes. With the HJS, there's no smell, so there's no thought that the car isn't stock underneath either.
            Back home, do the reverse
ID:	153003 Click image for larger version
            Did a little polish/wax
            Till next time...
              Beauts
              SS "S" pipes out
              New gaskets:
              Hello
              In the wild:
              could I get the part number for hJS cats plz?
              I fed up from the smell of exhaust
                Here's one for sale:
                You can go on Turner or ECS's website to get the SS part #. I don't recall.
                  Hey T i was thinking of welding in some HJS cats into my SS catless 044012, would you happen to know the size of the pipes?
                    if it's for the v1 stepped like me, it's 2.5" or 63.5mm o.d.
                      it is, Thank you buddy. looking at the prices might have to invest in a new set of pipes from SS. Might wait for a good sale this year.
                        Getting ready for 2022 now. No big plans, I still have a rear seat delete to get to, but am just doing a maintenance polish and seal with Mother's CMX protocol to get the car to its glossiest.
                        This is CMX polish with green (light polish) CSS pad, then CMX sio2/tio2 "ceramic" sealant applied.
ID:	159011 Click image for larger version
ID:	159012 Click image for larger version
ID:	159013 Click image for larger version
                        First meet of the year for me (end of Jan), in Malibu
                        I missed having some exhaust noise too much, and put the OM SCORZA muffler back on. Kind of a shame, because I got the stocker perfect with the lemans tips, but oh well. The tips on the the og scorza are already perfect. Just needed a little polish.
ID:	159016 Click image for larger version
ID:	159017 Click image for larger version
ID:	159018 Click image for larger version
                        I got some videos I'll have to upload to youtube and link here. Car sounds so good. I think it was a little too much last time, being catless, but with the HJS cats now, it sounds so good. The HJS cats do calm it just a tiny bit, but not that much. The HJS are not "stuffy" sounding like most cats.
                            Sounds great. Car looks beautiful as always.
                            Past: '99 Hellrot/Dove M3 | '97 S14 1JZ | '06 Triumph Daytona 675 | '01 330I M-Tech I '99 Silvia S15 | Current: '96 Estoril/Black M3
                              Thank you!
                              OP updated with mods list
                                My in laws got me the official Cobra Nogaro lumbar support.
                                Click image for larger version  Name:	NogaroLumbar1.jpg Views:	177 Size:	125.4 KB ID:	175240
                                Click image for larger version  Name:	NogaroLumbar3.jpg Views:	176 Size:	91.8 KB ID:	175241
                                It works great, but I don't love the nutsack sticking out
                                Click image for larger version  Name:	NogaroLumbar4.jpg Views:	187 Size:	100.9 KB ID:	175239
