Vegas 2006 Imola 6MT Coupe Refresh
    Thank you . . . That project is definitely on my todo list.
      Looking good man.Cheers to this being your last e46 m3.🥂
        nice progress man!
          Valve adjustment and new plugs.
          Click image for larger version  Name:	FD0C898D-87A4-4FC1-AC8D-A0EAAD684865.jpeg Views:	270 Size:	201.3 KB ID:	40693
            Lots of little things I finally got done.
            Passenger side mirror
            The shark fin antenna gasket was mangled when it was removed to install the wrap from the previous owner.
            Rear quarter trim seals and gaskets for both sides. No fun at all! Lots of goo gone and letting it soak.
            The factor crimp was replaced with a worm gear. I put it back to the way it should be.
            The front headlight trim had disintegrated.
            Replaced another worm clamp with the proper factory one.
            Missing wire holder for + cable.
            New belt, fan/viscous coupler, coolant cap
            Missing passenger seatbelt cap
            Missing door handle screw cap
            B and C Pillars
            Fixed a bunch of broken tabs on the door panels too.
            Fuel Filter. No picture on the car as I didn’t have a lift to replace it
              Gave the engine bay a quick rinse and dry.
                nice pick up ! love Imola !
                I thought i was the only one that had this gooey stuff run down the firewall and eat my paint. now I see you have it too, anyone know what it is?
                2007 Imola Red Z4M Coupe
                  No idea what it is, but I have it too.
                    I think it might be cosmoline but not sure. It was on my silver one too.
                      Yea, I have that too...noticed it in a lot of other e46s.
                      Great progress on the build!
                        Swear reading through your journal was like looking at a mirror of mine. Awesome work and attention to detail with the clamps. Makes me want to look through all of mine now.
                        Build Thread
                          Haha, right! I just read through your journal and you’re not kidding! Your M is coming along great. My wheel is destroyed but luckily I’ve found another in good shape. I won’t have it til the end of the month though. Can’t wait to get it installed.
                          I still have rod bearings and subframe to do. Hopefully no cracks and I’ll be doing the foam again.
                            Originally posted by 8000RPM
                            Getting a few more bits cleaned up on the car.
                            Missing vent on the battery
                            Fixing some clips on wires and washer tubing
                            Sunglasses tray because I live on the sun
                            Caps for seat bolts
                            Broken photo links
                            Build Thread
                              Hmmm, thanks for the heads up. I’m also getting error messages now on post size too. I’m going to delete and re-post.
                                Replacing some broken clips.
                                Caps for the seat bolts
                                The battery vent tube was disconnected. I had to get a new elbow to connect to the tube in the rear fender.
                                Got a sunglasses tray as I didn’t have one before.
