Originally posted by S14
View Post
Obioban's 2005 IR/IR Coupe
I'm feeling really dumb about this-- I really don't know how I missed that FCP sells the DS11s in these sizes! Never would I intentionally choose a "hybrid" pad, if I knew a track pad exists.Originally posted by S14 View Post
OK, you're pretty well read on most subjects, So what am I missing here?
When I plug in a 2002 porsche 911 into FCP's website, I get both the DS2500 and DS11's. A few months back you could get Hawk DTC 60 or 70 for the 911, but I don't see those offered any longer, weird.
https://www.fcpeuro.com/products/por...acing-frp3051w
https://www.fcpeuro.com/products/por...acing-frp3051h
is a 2002 911 Carrera the wrong car to find parts for the 996 brembo upgrade?
DS2500 is a hybrid street/track compound, if they were trying to slow you down on nitto's, no wonder they didn't last!
$400 flushed down the toilet...
If it makes you feel better, their catalog has DS2500 much more widely available than DS1.11s. I only saw the DS1.11 when I was browsing for the 997 at one point.Originally posted by Obioban View Post
$400 flushed down the toilet...'03.5 M3 SMG Coupe - Jet Black / Black
Time for a large project.
Wavetrac diff (stock ratio, because I hate more aggressive diffs) and diff rebuild (seals and bearings)
CMP subframe bushings
Monoball adjustable rear lower control arms
vincebar
Slonik rear plate
... and sort of related, the FCM rear shocks and spring are part of this as well (front, too, obviously)
Do you end up changing you spring rates? What did you decide in with the new FCM dampers?Originally posted by Obioban View Post
vincebar
Slonik rear plate
... and sort of related, the FCM rear shocks and spring are part of this as well (front, too, obviously)2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
