Hey Obiodan, those ohlins are the regular R&T? Well the AW does 'look' like it's rolling over more than your car.
Obioban's 2005 IR/IR Coupe
Originally posted by enjoy_m3 View PostHey Obiodan, those ohlins are the regular R&T? Well the AW does 'look' like it's rolling over more than your car.
375 350
700 628
... though with a GC race front sway set to full stiff, which is doing way more for roll stiffness than the springs are :P
(sway bar is 69% of roll stiffness for that setup)
Originally posted by Malloy View PostHey Ian, what shifter do you run?
Stock knob (and will be staying that way).
I currently have a 20% auto solutions kit. Next time I have the trans out, I will swap it for a 0% auto solutions kit.
Stock knob (and will be staying that way).2005 M3 - SGM, 6MT, Impuls Cloth, Slicktop
2022 M3 - BRG, Tartufo, xDrive
Yes. My brother has the 0% in his car, and it is perfection.2005 M3 - SGM, 6MT, Impuls Cloth, Slicktop
Originally posted by Obioban View PostLarger screen Avin installed:
Edit, found it
https://avinusa.com/8-8-multimedia-n...x69088e46.html
man that is sexy looks a lot better than Avin Avant 4 that has a lot of buttons i dont really needLast edited by Tonggi; 09-28-2021, 06:10 AM.
Originally posted by Obioban View PostStreet review of wavetrac: indistinguishable from stock.
I ask cause I was driving around with the back seats down the other day and I could hear the diff clunking away pretty clearly. The clunks correlated with that extra notchy feeling that sometimes happens when switching gears (almost as if the whole drivetrain is loaded up and needs to unbind before the gear can be selected).
I'm starting to think that most of the gripes I have with how my transmission feels are due to my diff. Actually, I remember there was a noticeable improvement in shift feel when I swapped out the diff fluid right after buying my car.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Saw you say on another thread that the wavetrac diff is quieter than stock since there's no m clunk. Have you noticed any differences in shift feel with the new diff?
I'm starting to think that most of the gripes I have with how my transmission feels are due to my diff. Actually, I remember there was a noticeable improvement in shift feel when I swapped out the diff fluid right after buying my car.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
I suppose I know what you mean-- you can feel the M clunk in the shifter. I do not, anymore.
I don't think I've ever noticed it correlating with extra notchy shifts, so I can't say I feel like that is reduced.
Originally posted by oceansize View PostWhen I swapped in my rebuilt 3.91 diff from diffs online last winter I can say almost all my clunk vanished. Shifts are much smoother now (however I'm in SMG), will be interesting to see how long that lasts. I had 100k on my original diff. I know this is Obi's thread but thought interesting enough to share.
Hmm.
And maybe "extra notchy" is not the best way to describe it. What I'm talking about is the feeling that happens when you try to switch gears fast and don't let the drivetrain "settle". The shifter becomes harder to push into the gate and when it finally does go in, you can feel the drivetrain clunking through the shifter. Doesn't happen on every fast gear change, but it happens often enough to be annoying.
I think you both have convinced me to start planning a diff refresh. Need to spend some time deciding what I want on the car first though.Last edited by heinzboehmer; 09-30-2021, 07:20 AM.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Interesting. 125k on mine, so I think it could use a refresh. Now I want to drive a higher mileage car with a refreshed diff to see what that feels like.
That's good to hear.
Is your CSB replaced? I'd do that first, if not.
Might be worth going over everything before diving into a diff replacement though.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
