Originally posted by heinzboehmer
Obioban's 2005 IR/IR Coupe
Cool yeah that's what I thought. Any idea on the complexity of the coding? Might be fun to experiment with and without on track if flashing the thing is easy enough.
E9x generation MK60 modules are flashable via WinKFP so I thought that might be a good starting point to learn how to hack these things... but I can't figure out what kind of CPU the code belongs to to even disassemble the software. It's something made by Motorola/Freescale, but it doesn't appear to be ARM, PPC, or HCS12. Not sure what else to try
Ah that kinda sucks. But also sounds like an interesting thing to mess around with. Might give disassembling the E9x code a shot sometime.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
So, this weekend I did my first track event with the 996 brake setup. Results were... mixed. Running DS2500s front and rear (the only track pad FCP sells)...
pros:
-no fade
-pedal feel was good
-braking performance didn't feel worse in any way
Cons:
-I went through an entire set of pads in 2 days on track (vs 6-8 events on the brembos with RE10s, so figure 17-18 days on track)!
-pad deposits were formed, though they self cleaned when back to driving on the street (deposits did not form with the brembos)
... this is with my car having huge brake ducts and it being a moderate temp weekend (high of 77, low of 58, on my time on track).
So, not sure what to do. I'm going to stick with keeping the brembo in reserve for the short term. If FCP didn't exist, it would be a no brainer-- I'd be back to the Brembos immediately. But, with FCP math... a different set of pads every event actually isn't worse, per se... since I'm swapping between streets and tracks either way (so it's not even more work). It just feels a little abusive of their warranty...
I don't know, not super stoked-- I was hoping they'd do better, especially given my massive amount of ducting and 10% lighter than stock car.
Rotors (ZCP/CSL) didn't form any microcracks, so that's good.
That matches my experience with DS2500 equivalent pads to a T. My usage was on a heavier (3800 lb) & 500+ HP car, but on Super Sports. They *disappear* but at least they don't lose bite. Sounds like you got them even hotter than I did, because I've never gotten deposits I could feel in the pedal, though the rotors don't look pretty.
What ducting do you have? Are you running hoses or just oversized funnels in the bumper without hoses?'03.5 M3 SMG Coupe - Jet Black / Black
Originally posted by r4dr View PostThat matches my experience with DS2500 equivalent pads to a T. My usage was on a heavier (3800 lb) & 500+ HP car, but on Super Sports. They *disappear* but at least they don't lose bite. Sounds like you got them even hotter than I did, because I've never gotten deposits I could feel in the pedal, though the rotors don't look pretty.
I couldn't feel the deposit, but I could see and hear them.
hard motorsports ducts and backing plates. So, my entire fog light area is being funneled directly into the rotor.
I couldn't feel the deposit, but I could see and hear them.2005 BMW M3 ZCP Black/Black - HTE Tuning | Kassel CSL DME | 280/272 Schrick Cams+P54 Followers | Dinan TBs | Bosch 550cc | Radium Fuel System | Karbonious CSL Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91, 3 stage clutch | FCM 336/600 | Vorshlag Camber Plates, RSM | Rogue ASP | AKG FCABs, SFBs | TMS Front Sway, Camber Arms, Monoball RTABs, Pullies | Mason Race Strut + X-Brace | AS 30% SSK | SPAL | Redish Plates | VAC Exhaust Hub | WPC Rod Bearings
Can you please explain what you mean by “feel the deposit”?
Looking around at race pads for the 996 calipers, the pads are ~half the price of the same pads for the brembo calipers. I suppose if they last at least half as long, that'll still put me in free rotors through FCP... so I could fall back on that...
Feels exploitative to be doing a pad swap through FCP for every single track event I do (which seems likely it'll be necessary if I stick with the DS2500s)
Eh... the wob wob wob through the pedal and steering wheel that you feel when you hit the brakes, that people frequently call warped rotors (but aren't).
I've only gotten bad deposits I could feel with Carbotech pads.'03.5 M3 SMG Coupe - Jet Black / Black
Originally posted by Obioban View PostLooking around at race pads for the 996 calipers, the pads are ~half the price of the same pads for the brembo calipers. I suppose if they last at least half as long, that'll still put me in free rotors through FCP... so I could fall back on that...'03.5 M3 SMG Coupe - Jet Black / Black
I think FCP also has ds1.11 and hawk dtc60/70 pads. Not sure about sizing for pcar calipers.
Youtube DIYs and more
Originally posted by Apex_80 View PostIan, do you run any temp paint on the rotor or caliper? Would be interested to see if perhaps you're overcooling as opposed to the pads overheating.
Originally posted by Obioban View PostRunning DS2500s front and rear (the only track pad FCP sells)...
When I plug in a 2002 porsche 911 into FCP's website, I get both the DS2500 and DS11's. A few months back you could get Hawk DTC 60 or 70 for the 911, but I don't see those offered any longer, weird.
https://www.fcpeuro.com/products/por...acing-frp3051w
https://www.fcpeuro.com/products/por...acing-frp3051h
is a 2002 911 Carrera the wrong car to find parts for the 996 brembo upgrade?
DS2500 is a hybrid street/track compound, if they were trying to slow you down on nitto's, no wonder they didn't last!
