Obioban's 2005 IR/IR Coupe
    Scary part of the Vincebar install complete. All glue, rivets, and paint from here.
    Click image for larger version  Name:	IMG_0889.jpg Views:	0 Size:	240.7 KB ID:	89147
    Great job 👍 did mine Vincebar 6 years ago with this glue, rivet method as well, holding up very well up this day no issues after all track day abuse.
      Well, the scary part is done. Just seam sealer, paint, and reassembly to go. Well, and the Slonik plate.
      ^the missing rivet in the first picture was added right after I took the photo.
      I've really discovered how much chassis coat they used everywhere in my car after replacing the rear floor, at ~100,000 miles. The stuff's everywhere
        Looks good! did you drop the subframe to replace the front bolts? I remember the oe ones have that hex head that sits between the chassis and bushings.
          Yep! See post 222 on.
            Which monoball ARCAs did you go with?
              Wow dude. I can’t even imagine doing this type of work myself. Looks great 👍👍
                This is not a recommendation, as I'll probably have a bad experience (based on previous experiences with the company, but Bimmerworld.
                  I've had the GC monoball ARCAs for around 1500 miles with no issues. I did ask what they used and they said strictly delphi/lemforder for 5/7 series (I know you cracked open a different part of theirs back in the day and it wasn't). What is the indicator there is a problem? Noise/squeaking, or just how long they last?
                    I popped the bimmerworld RTABs open because they started making noise after ~5000 miles. My hope is that they learned their lessons and are doing what they claim these days :P
                      So far so good with the Proxxon on. I had 3 dremels fail during this project. The Proxxon has already put in more time then all of them combined, and no magic smoke.
                      It does seem to have an overheat sensor, and shut down if it triggers. Which is a good idea!
                      I got this one: http://www.proxtools.com/store/pc/vi...&idcategory=26
                      I think I don't have enough understanding of how diffs work (why BMW put that slop in there to begin with) to decide if something like that bevel washer is a good idea, so I went without. The safe route :P
                      I am curious as to why you used an electric dremel type tool rather than a pneumatic die grinder. More precise? Less mess?
                      Thanks.
                      Jesse
                      Old, not obsolete.
                        Thanks.
                        Jesse
                        I really didn’t want to cut too much.
                          Ahhhh, I had forgotten it was bimmerworld and not GC.
                            How would you rate the DIY toughness of the rivet style Vinebar? I’ve been considering it, although it make make sense just to weld it in if I am doing plates at the same time so I don’t need to drop the subframe twice.
                            Build Thread
                              It's not actually hard to do... just stressful (and a bit time consuming). If you can handle vanos lockdowns, you can handle this.
                              It might seem more time consuming to me than it actually is, as I've been doing it one baby nap at a time, for the duration of said baby nap.
                                Subframe, drive shaft, and muffler back in. All downhill from here. Not even any heavy lifting left to go :P
                                Hopefully the Slonik plate gets here soon, or it's going to become a next winter project...
