Forgot to post the carbon fiber doors that were finished
The Red Drift ///Machine - 2026 NASA TT4 adventures
Not a PR, but close. 1:40.9. PR is a 1:40.5.
I have a deal with myself. No fast, sticky tires until I get into the 1:39s on these RRs. I might have to break that deal. I think I can get there but its going to take the moon, stars, god, heaven, hell, and everything in between to align.
I'm learning more from the aero testing. Someone brought up using a rear mounted radiator. Also seeing how a gurney can make such a big difference with air extraction...its got me thinking.
Jae, I feel like I've seen you talk about wanting a slanted radiator setup before. Was just recommended this video, which shows a carbon piece that does just that: https://youtu.be/uUSk5w5G4W8
Maybe you could even recreate (improve?) it...2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yes, I have! It has been something that I've been brainstorming but haven't been able to figure anything out that doesn't require major modifications. Ideally, I could make something and sell a couple of parts to replenish the slush fund.Originally posted by heinzboehmer View PostJae, I feel like I've seen you talk about wanting a slanted radiator setup before. Was just recommended this video, which shows a carbon piece that does just that: https://youtu.be/uUSk5w5G4W8
That's an interesting way to mount the radiator - to a shroud and then the shroud to the frame rail. Ultimately, I'd like to try and close off the kidney grills for aero efficiency and take the intake air from the foglight ducting and headlight if needed.
I think I could get by with a smaller radiator and less oil cooling by increasing the airflow efficiency - also reduces weight with less radiator, fewer lines and hoses. BUT...I've got a lot of learning to do. The first step I'm taking is to learn more about aero - specifically air flow patterns and what effects the air pressure differential across the radiator and how it affects cooling.
The part I haven't figured out is the ducting on the back of the radiator. The airflow needs to be laminar to lower the pressure. Right now, the air needs to make 3 90 degree turns which will result in flow detachment and turbulence - higher pressure and reduced cooling performance. The real challenge is how to maximize laminar flow. The first step I've taken is to do some wool tuft testing. I understand the flow across the hood and windshield. I need to figure out how to capture flow on the front bumper. Thinking of using a gopro on the front straight pit wall. Once I get a better understanding of the flows on the front and sides of the car, I will start making some changes. Not sure what those are yet.
Thanks for the thinking of me! That video has given me more options to think about.
That sounds like an interesting exercise in finding the optimum point. Decreased effective surface area with the tilted radiator will likely play a big role as well. Although you could offset a good chunk of that with a properly designed shroud.Originally posted by bigjae46 View PostI think I could get by with a smaller radiator and less oil cooling by increasing the airflow efficiency - also reduces weight with less radiator, fewer lines and hoses.
Leafblower? Should at least give you a good idea of what the air is doing.Originally posted by bigjae46 View PostI need to figure out how to capture flow on the front bumper. Thinking of using a gopro on the front straight pit wall.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - SSV1 - HJS - Mullet Tune - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Not sure if I mentioned it but the goal for 2025 is to set TT4 NASA track records for the TX region. I'm 90% confident that the car can do it as is. But I do want to run TT3 where my car is at a significant tire disadvantage. My car is lighter (duh) but there will be a HP and tire deficit. So I have to out drive other cars with stickier tires and more power. The power disadvantage becomes obvious on long straights - the car just runs out of steam over 120mph due to drag. So I will continue to optimize the weight - first step is to get below 2500lbs. I'm getting closer, an estimated 2525lbs right now (2615 minus 15g of gas - 90lb = 2525). 2nd half of the year - work on drag reduction and hopefully a suspension upgrade.
Lots to do before the first NASA event that I can attend this year. Detune, ballast installation, and test, test, test.
First step is to get some laps in at MSR Cresson and Eagle's Canyon. So event #1 - MSR. Previous PR is a 1:20.1. I'm very happy to say that I was running consistent 1:18's, PR 1:18.4. There are things I need to do to optimize for MSR since it is a smooth track compared to MSR Houston. Virtual best was a 1:17.1 which is a massive delta to the reference lap. I need to close that up and be more consistent sector to sector before I can start fine tuning. Running 2 year old Toyo RRs with a bunch of heat cycles. So an easy extra .5 second gain with just tires.
It was going really well. Mid 90's through Riccochet, happy with the speed everywhere else except for Big Bend.
Then this happened...
Came out as good as I could expect. Car was still drivable, no noises or issues but the car felt sick. Got it home, found a damaged splitter mount and control arm. The ball joint blew up yet it made zero noise. Fixed and ready for more!
Getting ready for NASA in Houston! Working on a detune with Epic. It has been an adventure with my home-cloned ECU 🤣.
Meanwhile, working on some carbon parts.
Front strut tower plates that I can bond to the car. Stock parts are 1.5lbs, carbon parts are .3lbs.
And some rear spring plates - top and bottom. I don’t really need the weight jackers. Its not too
difficult to mess with the rear ride height.
Carbon seat mounts…eh…need to make some changes to the layup. 4mm thick is challenging to cut. Also, I don’t think the top holes are usable. I started drilling the holes but it is too close to the edge. Not sure I’d use that hole with a steel mount.
Impressive.Originally posted by bigjae46 View PostNot sure if I mentioned it but the goal for 2025 is to set TT4 NASA track records for the TX region. I'm 90% confident that the car can do it as is. But I do want to run TT3 where my car is at a significant tire disadvantage. My car is lighter (duh) but there will be a HP and tire deficit. So I have to out drive other cars with stickier tires and more power. The power disadvantage becomes obvious on long straights - the car just runs out of steam over 120mph due to drag. So I will continue to optimize the weight - first step is to get below 2500lbs. I'm getting closer, an estimated 2525lbs right now (2615 minus 15g of gas - 90lb = 2525). 2nd half of the year - work on drag reduction and hopefully a suspension upgrade.
Is the 2615 with driver??
Got the dyno sorted out. It was an adventure. Home coding caused issues and a delay. Got it done.
337hp/266tq - quite happy!
Then the detune. I was running out of time on the dyno, power kept going out, and it was an all around shit show.
Got it down to 286. Needed to be at 280. Not going to run the detune until the fall anyway.
Nice results!Originally posted by bigjae46 View PostGot the dyno sorted out. It was an adventure. Home coding caused issues and a delay. Got it done.
What is "home" coding? Did you DIY the tune?
It's been a rough start to the year - had the off track excursion, damage repair, tune issues...haven't had a clean weekend yet.
I've been storing the car at the track which is 40 minutes away. Its great as long as you don't need to work on the car. There are tools and stuff but the logistics have been painful.
Nonetheless, need to get ready for NASA. PCA event needs to go smooth for me. Luckily it did. Got to test the tune, although it was the detune and not the full power tune that I will use at NASA. That's how much of an improvement the Epic tune made, can't really tell the difference. Although at the end of the day I was thinking the car felt kind of dead up to redline.
I like the idea of learning about the airflow around the car to get data instead of blind guessing. The hood, trunk, and roof are easy. Not so simple for the front, back and sides. So I'm experimenting with one of the long arm suction cup mounts and it worked great. Well, just well enough for the GoPro stabilization to make the footage usable. Over the summer I do plan to collect better baseline data especially on the front end. The last thing I need to figure out is getting video from the under the car.
I've exclusively used NT01s and RRs for the last 13 years except for a set of Hankook Z214s. They are cheap and durable AND I wanted to rely on the car and improving my skills to optimize lap times vs throwing on stickier tires. Well, I think I'm about there. Literally chasing 2-3 tenths.
Enter Falken RT660s. 275/40R17s are $1100 per set incl tax! These tires are WAY better under braking. I'd routinely activate the ABS with the RRs, much different with the RT660s. Did a 1:41.8 on the detune in my 2nd session on the RT660s. It wasn't a very lap either.
Excited to see if I can put it together this weekend at NASA.
