The Red Drift ///Machine - 2026 NASA TT4 adventures
    Excited for the future projects! Except the carbon side skirts. Those seem like a big waste of time unless they’re done with/after the flat floor.
      Yes, the carbon side skits are to partly offset the added weight from the flat floor and a potential attachment point. I was planning the flat floor and then saw a car with a recently installed flat floor burn down at NASA. This is forcing a rethink. I know I don't want to do a partial floor with an exhaust cut out. I've been brainstorming an idea to build a heat shield around the exhaust and force air between the exhaust and heatshield. This paired with swaintech coating the first two exhaust sections could control heat well enough so it reduces the heat which reaches the fuel lines and transmission which means less shielding around the fuel lines and less cooling capacity for the transmission and to a lesser extent the diff.
      I also might go full carbon exterior. I have a lead on a rusty roller chassis with good side panels. Then all I would need to do is the rear bumper.
        Flat floor with a ducted heat shield section in the center sounds like the move. You could add a couple naca ducts to bring air in and over the exhaust without adding much of a penalty to the flat floor (actually may even help!)
          That's one option. I need to tilt and duct the radiator / oil cooler first, see how that affects the static pressure under the hood. May want to force air from the engine bay over the exhaust. Have the heat shield act as a duct to guide air down the exhaust.
            Sounds like a spicy cabin for the driver
              I made some replacement plates for the kevlar front bumper reinforcement bar - forgot to take pics. Also ran out of adhesive and forgot to take pics. I run a bolt through the left side in addition to the bolt from the factory on the right side. I think this will help the whole assembly survive a couple of tows. I am considering using strut mount nuts to hold the rebar onto the frame rail. More thread engagement and easier to install. I think these plates can be used to repair kevlar rebars with damaged aluminum plates and also create a spot for splitter mounting. More to follow on this.
              The front bumper is a success! It is finally on the car after 3 failed attempts at making a mold and the mounting complications. Not finished, still have some details to work on. Fitment is pretty good, just need to make an adjustment on the left side latch pin. I think I am going to just glue on the center grill and also need to install a gasket around the left fog light opening to seal off the duct.
              The one complication I did not foresee is the splitter height needs to be more precise since carbon is far less forgiving than plastic. The front splitter needs to be lower. While I have height adjustments at the two primary mounts, the outer mounts don't since they are eBay box lid struts. Also, need longer front support struts. Currently brainstorming how to add adjustability with the shocks. I want to keep some sort of shock in place, they have done a great job of being a firm mount while allowing some upward forgiveness when scraping. The upside is I get to trim more carbon off which I'll be a couple more ounces lighter! Lol
              Once I lower the splitter, the bumper will be very easily removable. Hopefully I can still load the car onto my trailer using race ramps with the splitter on. The splitter takes less than 5 min to take off and pin it back on for transport. It is still a chore I'd like to avoid at the end of a long hot weekend.
              Click image for larger version  Name:	IMG_6326.jpg Views:	4 Size:	113.6 KB ID:	364186
              Click image for larger version  Name:	IMG_6328.jpg Views:	4 Size:	115.1 KB ID:	364187
              Click image for larger version  Name:	IMG_6329.jpg Views:	6 Size:	118.2 KB ID:	364189
              Thinking of a new name since it is only about 33% red.
              Click image for larger version  Name:	IMG_6330.jpg Views:	4 Size:	128.5 KB ID:	364193
              With it being around 100 degrees outside...close enough for now. Someday I'll order a TT4 decal...
              Click image for larger version  Name:	IMG_6331.jpg Views:	4 Size:	154.0 KB ID:	364195
              Forgot to snap a pic of my new compression molded carbon fiber floor mount seat adaptors. 29 layers of carbon, 6 layers of kevlar - 3/8' thick solid carbon/kevlar.
              My current carbon mounts were vacuum infused in 2 halves and bonded together to a similar thickness using mostly unidirectional layers. Learning has occurred and decided to use a 2 pc compression mold which creates more compaction than vacuum infusion. This achieves a better higher fiber:resin ratio which results in a stronger, stiffer, and lighter part.
              2.6lbs for the inner and outer mount. I think it will be slightly more than what's in the car but the new mounts are also a little thicker (6 more fabric layers).
              Click image for larger version  Name:	IMG_6316.jpg Views:	4 Size:	58.7 KB ID:	364188
              My spare fenders are done. Really odd how one side is .6lb heavier than the other. I measured three times. Both sides are similar in stiffness. I did mess up and had the bag tape come undone - didn't clean off the release agent from underneath - so I temporarily lost vacuum. Not sure which side it was but it shouldn't have resulted in that much more weight. Both sides used a similar amount of epoxy. First time I've been that off on a left-right or like part. That's one thing I've been fairly consistent at.
              Click image for larger version  Name:	IMG_6345.jpg Views:	4 Size:	111.5 KB ID:	364192
              Click image for larger version  Name:	IMG_6347.jpg Views:	6 Size:	88.6 KB ID:	364194
              Click image for larger version  Name:	IMG_6348.jpg Views:	6 Size:	114.1 KB ID:	364190
                First time on track since May with Heinz's strut brace, Bry5on's wheel well reinforcements, and carbon front bumper and fenders. Normally MSR Houston is terrible in the heat. I'd describe the feel of the track as slimy meaning the car just slides. Understeer right into oversteer.
                I wasn't pushing the car but holy shit the front end felt so much more responsive in conditions where it would normally be mush. This is a HUGE improvement! Thanks for heinzboehmer and Bry5on for their excellent ideas!
                FINALLY!!! I should be under 2500lbs!
                2557lbs with a pass seat, harness and 35L of fuel. Realistically, around 2485lbs dry - no fuel, no ballast.
                Click image for larger version  Name:	IMG_6403.jpg Views:	0 Size:	90.4 KB ID:	366328
                At some point, I will make the E86 braces from carbon tubes. I'll be buying them from Dragonplate.com. Not sure about the center bar.
                Click image for larger version  Name:	IMG_6371.jpg Views:	0 Size:	111.7 KB ID:	366324
                Carbon fiber strut tower brackets
                Click image for larger version  Name:	IMG_6369.jpg Views:	0 Size:	88.6 KB ID:	366325
                Click image for larger version  Name:	IMG_6368.jpg Views:	0 Size:	82.5 KB ID:	366326
                My cheeseball carbon fiber HVAC cabin air filter block off plate.
                Click image for larger version  Name:	IMG_6390.jpg Views:	0 Size:	96.6 KB ID:	366327
                  Hell yeah! These changes make the car so much more controllable near the limit, you need to relearn where the limit is. Glad you’re digging it! Time for some PBs
                    Awesome! +1 to Bryson's comments. Glad the changes lived up to expectations.
                      Nicely done. Fab work looking good.
                        Steering rack rebuild with a used rack that I got cheap a year ago. Mine is leaking pretty bad so the time is now! Started out excellent! Got the inner seal out rather easily with a 22mm socket on a long extension.
                        Click image for larger version  Name:	Steering Rack 1.jpg Views:	0 Size:	120.2 KB ID:	616413
                        Then the shit show. The pinion seals aren't even close to fitting...I tried. Luckily I bought from Amazon so I got a refund for TWO seal kits. What a massive waste of time. To fix my rack leak, I pulled the pinion from the rack in the car, replace the seal and bearing and put it all back together. I'll deal with it all later.
                        These white teflon seals don't fit. Pending attempt #3...more seals on the way.
                        Click image for larger version  Name:	Steering Rack Seals.jpg Views:	0 Size:	72.8 KB ID:	616412
                        Onto NASA in Oct at MSR Cresson. I need two good finishes here to be in a good spot for the season points win. FCM suspension arrived a week before the event and had an issue with the camber plate top nut. Needed a different bushing which arrived a day late. Vorshlag...not impressed. Called Fri, followed up Mon - no one knew anything, called Tue - said they would get it to me ASAP. Shipped it ground from Dallas to Houston but it wouldn't arrive until Thu night. WTF...but at least I don't have to f with a new suspension.
                        Ready to go! People ask what car am I driving - I tell them the red M3. They all say they haven't seen a red M3...then I tell them the black one. lol
                        Click image for larger version  Name:	Red Drift Front.jpg Views:	0 Size:	163.8 KB ID:	616414
                        Click image for larger version  Name:	Red Drift Right.jpg Views:	0 Size:	202.4 KB ID:	616415
                        Click image for larger version  Name:	Red Drift Rear.jpg Views:	0 Size:	219.5 KB ID:	616416
                        It was windy...zip ties to keep the car cover on overnight!
                        Click image for larger version  Name:	Car Cover.jpg Views:	0 Size:	81.4 KB ID:	616417
                        Placed 3rd on day 1 and 2nd on day 2. The most fun I've had on track in a looooong time! Both days, had a session where I was fastest but wasn't on the fastest session. The good news is I know where I'm leaving time on the table. Also, I'm in a good spot, 195 points up after this weekend. A win is 100 points. Would be better if I was 205 points up so I could skip the last event.
                        A 1:17.89, winner was a 1:17.64. Damn big bend!
                          Time to move the car back home. I was keeping it at the track which was convenient on track days but working on it was a nightmare. 40 min drive, forget something, done for the day.
                          First step, install the WPD ... Wife Protection Device. Especially with the swan neck putting the end plate at head height.
                          Click image for larger version  Name:	Wife Protection Device.jpg Views:	3 Size:	146.0 KB ID:	616430
                          First, my Bimmerworld Race is hanging on by a thread! It is the original version, probably 15 years old? Bought it used 11 years ago. It has been repaired 4 times...I'm running out of bubble gum to keep this together. Slipped on a repair sleeve and welded it on. Just need to this to hold together for a little longer. I'm probably going to throw on the newer version of the BW race until I can get a TIG welder and maybe...learn how to weld Inconel?
                          Click image for larger version  Name:	Exhaust Failure.jpg Views:	0 Size:	80.8 KB ID:	616426
                          Click image for larger version  Name:	Exhaust Failure 2.jpg Views:	0 Size:	82.7 KB ID:	616427
                          Tire spats V1 - survived one event, lots of potential improvement here. The are angled forward a bit much, definitely lose man points, I think it is a bit much. Also some small gaps, nothing that duct tape can't fix for now, maybe later next year V2 will come out.
                          Click image for larger version  Name:	Tire Spat 1.jpg Views:	0 Size:	101.2 KB ID:	616419
                          Click image for larger version  Name:	Tire Spat 2.jpg Views:	0 Size:	132.6 KB ID:	616420
                          Click image for larger version  Name:	Tire Spat 3.jpg Views:	0 Size:	238.7 KB ID:	616421
                          It is time...FCM suspension install!
                          First, the bilsteins are about 5 lbs lighter overall. Weighed with camber plates / shock mounts
                          TC Klines
                          - Struts: 11.57lb
                          - Shocks: 6.35lb
                          FCM Bilstein
                          - Struts: 10.33lb
                          - Shocks: 5.2lb
                          Click image for larger version  Name:	TCKline Strut.jpg Views:	0 Size:	77.9 KB ID:	616424 Click image for larger version  Name:	TCK Shock.jpg Views:	0 Size:	82.3 KB ID:	616422
                          Click image for larger version  Name:	FCM Strut Weight.jpg Views:	0 Size:	69.8 KB ID:	616425 Click image for larger version  Name:	FCM Shock Weight.jpg Views:	0 Size:	99.3 KB ID:	616423
                          Installed
                          Click image for larger version  Name:	FCM Install 2.jpg Views:	0 Size:	65.1 KB ID:	616429
                          Click image for larger version  Name:	FCM Install.jpg Views:	0 Size:	56.5 KB ID:	616428
                            The FCM installation was easy breezy...the corner balancing and aligning sucks massive balls!
                            Happy that I got all 4 corners within 39lbs. That took half a day even with rear weight jackers. Still have some work to do since the left front is hilariously high but I need to get this prepped for the last time trial of the year. For some reason, getting the pre-load out of the front sway bar was a PAIN! I disconnected the sway bar for the corner balance and then the end links for some reason wouldn't cooperate when reinstalling.
                            I can pull more weight off the nose with an OEM radiator - the CSF is 5lbs heavier and it holds more fluid. Probably 7-8lbs total. I am going to redesign the ballast mounting. The GSR plate is outstanding but I'm sure I can get to 50/50 front to rear if I can move the ballast towards the rear by a coupe of inches.
Name:	Scales Full Weight.jpg
                            Now here is the mind-F part of it - the alignment.
                            The left front can get 1 degree more negative camber than the right AND the left sticks out a little bit more than the right. I want to be in the -4 to -4.5 range which is the sweet spot for the non-M camber plates. The right will only go to -3.5. I did damage the right control arm, right FCAB due to an off. Also had the right wheel bearing go bad. The TCK strut was straight so I suspect the right knuckle is bent. I have an extra subframe in case that got bent...IIRC it was the inner ball joint on the control arm that blew up.
                            The odd thing is I got -4.25 camber on the right corner with the TC Klines. x3 checked that the strut is fully seated, camber plate is at max caster, and on the correct side. I could always get more camber on the left side but not this bad.
                            I am also considering slotting removing some material on the strut tower to get more camber.
                            LEFT
Name:	LEft Camber Plate.jpg
ID:	616437 Click image for larger version
Name:	Left Camber.jpg
                            RIGHT
Name:	Right Camber Plate.jpg
ID:	616436 Click image for larger version
Name:	Right Camber.jpg
Name:	Tire poke - right.jpg
ID:	616440 Click image for larger version
Name:	Tire poke - left.jpg
                              Remind me which Bilsteins are the starting point for these? Real nice that it’s a weight reduction.
                              edit: TCK shaft could be bent too. It’s pretty thin.
                                First time on track with the FCM Suspension.
                                Started on a member day just to shake it down. First laps I'm just feeling it out. Feels ok but then I remembered I inflated the tires to 32 psi for the alignment. Came in, they were at 41psi. Let some air out, went back out, and then ABS fails into T3. Skipped turns 3, 4, and 5 and ended up at T6...🤣. I did remember my Autel tool - left front ABS sensor signal. Wire got pinched by the sway bar - damn. So...I have a spare. It would have been at the garage I was storing my car at. I moved out so it was at home. I remember debating do I bring my spare parts tote? Nope...won't need it. WTF...done after 4 laps.
                                Day 2 with Driver's Edge. The car felt good in the morning except the rear tires would not hook up. I ran the full power tune, not the 244hp TT4 tune...so wasn't sure if it was me, the track or the car. Others were complaining about a lack of grip so I am blaming the track. The track is shiet. The track surface is 21 years old...it sucks. I nicknamed the track "The Landfill"
                                Then I ran into dull understeer as it warmed up and got windy. Not the terminal type where the car just goes straight. But I turn the wheel and the car misses the apex. It felt like I really needed to slow the car to get it to the apex.
                                Did an alignment the next day and the front tires were toe'd in by quite a bit...enough to think that it would cause understeer. Probably from my safari adventure on Fri.
                                The biggest difference is the car is VERY comfortable even on 400/850lb springs. I drove 53 laps in one day, usually log about 40 at most. I drove 19 laps in 2 sessions back to back and I felt pretty good. The track is VERY bumpy and it gets quite brutal after about 8-9 laps. My foot didn't get bounced off the throttle as well. So in regards to smoothness and comfort - as advertised!
                                At this point, I'm disappointed in the lap times. Relatively fresh Goodyear 3Rs and good conditions, I expected to be much faster. My best was 1:41.3, my PR is 1:40.5 on Toyo RRs. There are other issues I have to solve - needs more negative front camber, the toe was likely knocked out of the desired spec, and the track was not good that day. I can't make a judgement on the FCMs yet, too many variables. We'll see where this goes.
                                The one thing I miss from my TC Klines is a hooked up and pointy front end with a rear axle that can easily and controllably be slid into place. The damned things just wore out. But I'd rather blow up an engine than change the suspension...what a pain!
                                More to follow on the FCM.
                                Next event is Dec 5/6 with PCA. Skipped the last NASA event, family stuff.
