Flashing the MK60 with ZCP software
    Anyone with an actual CSL willing to connect their computer for 20 minutes to pull down a dump of (presumably) an 813.3?
    CSL shares the same part number with the ZCP, so it should have the 817.3
Name:	Screenshot 2026-11-21 at 4.13.10 PM.png
Name:	Screenshot 2026-11-21 at 4.12.53 PM.png
    813.3 came in late model normal M3s (I think). Annoyingly, I was looking through pictures and the MK60 module I took out of my car to replace with the 817.3 was an 813.3...
      Click image for larger version  Name:	Screenshot 2026-11-21 at 4.13.10 PM.png Views:	0 Size:	41.9 KB ID:	616361
      Click image for larger version  Name:	Screenshot 2026-11-21 at 4.12.53 PM.png Views:	0 Size:	164.5 KB ID:	616362
      *should* .. interestingly, if it does then the ZCP technically has the looser oversteer limits due to the taller tires and the way the yaw prediction (and therefore threshold limit) is calculated.
      Well in that case, someone with an 06 M3 then? Man, what a bummer about the swap. Is the car still local?
        Which tool would be need to be used to download the firmware?
          Shoot a PM to heinzboehmer or me and we’ll get you onto an email chain. It’s a custom made tool just for reading the MK60 that Heinz vibed up.
            Bry5on & heinzboehmer My spare Mk.60 has 813.3 on the label. Is this the version we are after?
            I'll check the car tomorrow. It is an 03 faclift so perhaps too old ?
              That’s the one we’re after! Any chance you’re near San Diego or the Bay Area?
                I have 813.3 and 829.3 (z4m mk50e5) modules sitting on my work bench. I can dump the data for you.
                  Wouldn't it be easier to adapt the ZHP image to an MK60.1 instead?
                  They are practically free, and you can flash them through WinKFP, which makes future modifications much easier and more accessible.
                  The MK60 seems like an absolute nightmare from everything I've read so far. Having to physically cut the unit open just to flash it is a huge turn-off.
                  With the MK60.1, you also get an internal pressure sensor, and CAN messages can be adapted as well.
                  That said, I can understand the appeal of sticking with the MK60 once you've already started down that road. Sometimes you just want to see a project through to the end.
                    A software only flash is way more appealing than swapping hardware and building a custom firmware and vehicle model that may or may not behave as safely for most people. We’re still working to eliminate opening/physically accessing the MK60 module to flash if that wasn’t already clear.
                    That said, you’re not exactly wrong. The MK60e5 has a more detailed vehicle model that includes things like compensations for tires, as well as several other features. The e46 MK60 has an extremely simple vehicle model for calculating/triggering interventions. Porting the e46 model into a MK60e5 also does not appear to be trivial. The e46 CAN integration is the easy part.
                      Swapping the module is a bit of a pita, too.
                        813.3 would likely be one of the earlier MK60s. I’d expect to find it on an 03. They eventually changed to 818.3
                        i have an 817.3 in my car and 818.3 on my desk, but I think we have dumps of both already
                          We might have mislabeled mine and it could be an 813.3. I’ll get in there with a mirror. It’s byte identical to another 813.3 Ryan_R just shared.
                          and this numbering logic makes way more sense. I was wondering…
                            In that case I can grab an 818.3 dump. Just need to modify my bench harness to simulate ignition signal
                              Confirming here that mine is indeed 818.3 as I’d thought. Both 813.3 and 818.3 have identical part numbers and identical firmware images, so far as we can tell from the dumps..
                              Click image for larger version  Name:	IMG_1357.jpg Views:	0 Size:	154.9 KB ID:	616583
                              edit: here’s the byte identical 813.3 that Ryan dumped, for comparison’s sake
                              Click image for larger version  Name:	image.jpg Views:	0 Size:	120.6 KB ID:	616584​
                              edit2, while we’re at it. 819.3 is an ARM module with built in pressure sensors, looks more like the e5 on first blush with an image 2.5x the size of the MCORE earlier ones and has TX/RX CAN messages in the e46 parlance (ie: Z4)
                                Yes, this.
                                The whole goal of this project is to develop a tool to flash the E46 MK60 through the OBD port. We've solved the reading part of the puzzle, but not yet the writing part. One click update to ZCP FW beats swapping hardware.
                                If it turns out that you do need to cut the module open to flash, then you should definitely just deal with the brake fluid mess and swap in an E5. It's a much more capable module.
                                That being said, MK flashes the E46 modules to the race FW without cutting them open, so there's definitely a way!
