Hi! I'm going to do CSL airbox + schrick 288/280 cams. I have a question about fuel- will M3 E46 stock fuel pump and stock injectors will be fine with this mods?
S54 stock injectors max power
Barely. Headers too? You probably want to upgrade the injectors. If you do any headwork and TBs, definitely. Pump is fine.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
I have S54 in E30 so my setup is rebuilded engine, no porting or changed valves- only shrick DLC rocker arms and supertech valve springs. I have euro headers with custom double 2.5 inches exhaust, no mods on power except airbox and shrick cams.Originally posted by Tbonem3 View PostBarely. Headers too? You probably want to upgrade the injectors. If you do any headwork and TBs, definitely. Pump is fine.
Maybe during your dyno tune your tuner can see what the duty cycle is and how maxed out you are currently?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
You are 100% wasting your time if you don't upgrade injectors with cams. I have a built head with 280/272 cams and everything else imaginable and my car hilariously ran out of fuel on brand new oem injectors. Stock is almost maxed out of the box.
More aggressive cam = more fuel so yes you need them.2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
Which one do you recommend and how much flow I need? As I searched- stock 280cc, at least 330cc should fit well?Originally posted by thegenius46m View PostYou are 100% wasting your time if you don't upgrade injectors with cams. I have a built head with 280/272 cams and everything else imaginable and my car hilariously ran out of fuel on brand new oem injectors. Stock is almost maxed out of the box.
Just finished my engine build and made a respectable 370whp on a mustang dyno which is excellent but my flow matched stock injectors are maxed out and I need to upgrade to something with more flow. I was recommended at least 440cc like the bosch green giant as well as 550cc but am looking to see if there are any options that2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Yeah, definitely tuner will but I want to buy all parts before I finish airbox mods, not to waste time for waiting till injectors will be delivered)Originally posted by Tbonem3 View PostMaybe during your dyno tune your tuner can see what the duty cycle is and how maxed out you are currently?
I have bosch 550cc ev14 and they are plenty for NA. I'm making close to 370whp revving to 8500rpm and they are not maxed but I'm using much more fuel than laughable stock injectors.Originally posted by BMWfanz View PostWhich one do you recommend and how much flow I need? As I searched- stock 280cc, at least 330cc should fit well?2003 E46 M3 TiAg/Cinnamon 6MT
