S54 stock injectors max power
    Hi! I'm going to do CSL airbox + schrick 288/280 cams. I have a question about fuel- will M3 E46 stock fuel pump and stock injectors will be fine with this mods?
    Barely. Headers too? You probably want to upgrade the injectors. If you do any headwork and TBs, definitely. Pump is fine.
      I have S54 in E30 so my setup is rebuilded engine, no porting or changed valves- only shrick DLC rocker arms and supertech valve springs. I have euro headers with custom double 2.5 inches exhaust, no mods on power except airbox and shrick cams.
        Maybe during your dyno tune your tuner can see what the duty cycle is and how maxed out you are currently?
          You are 100% wasting your time if you don't upgrade injectors with cams. I have a built head with 280/272 cams and everything else imaginable and my car hilariously ran out of fuel on brand new oem injectors. Stock is almost maxed out of the box.
          More aggressive cam = more fuel so yes you need them.
          2003 E46 M3 TiAg/Cinnamon 6MT
          2005 E46 330i ZHP Imola/Sand
          Instagram:@thegenius46m
            Which one do you recommend and how much flow I need? As I searched- stock 280cc, at least 330cc should fit well?
              Just finished my engine build and made a respectable 370whp on a mustang dyno which is excellent but my flow matched stock injectors are maxed out and I need to upgrade to something with more flow. I was recommended at least 440cc like the bosch green giant as well as 550cc but am looking to see if there are any options that
                Yeah, definitely tuner will but I want to buy all parts before I finish airbox mods, not to waste time for waiting till injectors will be delivered)
                  I have bosch 550cc ev14 and they are plenty for NA. I'm making close to 370whp revving to 8500rpm and they are not maxed but I'm using much more fuel than laughable stock injectors.
