    Yeah, blocking filling seems interesting. What's TZ intervention? Is that ignition pull?
    Yup ignition pull (via the torque manager).
    Build Thread:
      "TZ" should be german for "Transitor Zündung", that should be just a variable definition/name for ignition angle.
      …under construction.
        I've been doing a bunch of work on figuring out the SMG module in the slave binary. This is one of the areas the least information is available on, so there's a lot to work through and figure out. I've been making some great progress though.
        There's 53 SMG functions in the slave binary, divided into the following sub-modules if you will:
        - Clutch (manipulation of the clutch)
        - Motor (e.g. motor torque and speed regulation)
        - Shifting (changing of gears)
        - Common/basic (init functions, the task functions, DPR, IPK, SK (safety concept), etc.)
        Of note is that the SMG module has its own IPK messages to transfer critical values between the slave and the master. Some of these come straight off the SMG canbus and go via the IPK to the Master, others are generated by the SMG module functions and the results are sent to the Master (e.g. torque and engine speed regulation for the SMG).
        The SMG also has its own freeze-frame generator for error reporting, so SMG-specific variables can be captured.
        I've got more work and cross validation to do before I share everything, but for now here's the function that handles the well-known "limiter shift lights". "K_SMG_DWF_CFG_HS" is the parameter that can be changed to enable shift lights for non-SMG vehicles.
Name:	Screenshot 2026-01-14 at 9.18.30 PM.png
Name:	Screenshot 2026-01-14 at 9.18.37 PM.png
        Build Thread:
          Appreciating this great work! Can't wait for the SMG to be finished so I can start on the 1st Gen DCT implementation: https://www.shop.rusefi.com/shop/p/ua-can-bridge
            If anyone is interested this http://www.kleinknecht.com/en/software_gredi4.htm appears to be the software that BMW used to testbed tune the S54 (and presumably other engines/DMEs of the era).
            There's a reference to "Gredi" in one of the funktionsrahmen documents and I saw it and was curious and a bit of a hunt unearthed this. This also explains what I'd previously noted about the "B" canbus channels which appear to be for transfer of data. Pretty sure the CAN Control Protocol that Gredi uses fits the bill.
            So kinda tangentially related, but I found this repo when scouring the internet for MSS6x stuff https://github.com/jakkuh/MSS65-Info and within that there seems to be something related to Gredi https://github.com/jakkuh/MSS65-Info...ain/tools/MCS4
            I don't think any of it is particularly useful as end users (even all the MSS6x binaries seem to be truly ancient - I doubt they'd function properly on retail hardware), but perhaps worth digging into a little more. I also need to look into info about that "2+ tb damos dump". The only similar collection I had seemed to be missing anything related to BMW M from what I remember.
              Awesome find!!
              I'm going to be scouring through this - there's a bunch of stuff in there about p_saug (manifold air pressure) and rg_m (residual gas mass) which will be super helpful cross references.
              Build Thread:
                There's a lot of information in those files - the MAP files have a listing of all the objects, in order, with function names.
Name:	Screenshot 2026-01-18 at 8.23.21 AM.png
                Build Thread:
                  Yeah there's actually some interesting insights in there. Have to interpret in context since it's early MSS65 rather than MSS54 info, but even skimming through it it's clear that the MSS65 concepts are evolution of the MSS5x and these are early enough prototypes that I suspect a lot of it is closer to the MSS5x counterparts than the final MSS6x. I imagine the map sensor stuff will be fairly close to the CSL implementation given these date back to 2002-2003 and the actual production M5 did not end up using a map sensor to my knowledge
                    well those ELF files make things easy :-)
                    Here's the MSS65 rf_berech()
Name:	Screenshot 2026-01-18 at 2.35.50 PM.png
                    Build Thread:
                      Okay - been having a bit of a look at this in more detail. It's extremely useful. As you suspect terra there are some fairly strong similarities between 0401 and this. They are far from identical, and the MSS65 code seems to be more advanced in some ways. But I've been doing a comparison on the residual gas mass functions. Good news is that my interpretation of them was correct. Secondly there's a bunch more parameter names I'm going to be able to confirm out of this.
                      Very cool.
                      Build Thread:
                        Calculation for exhaust gas back pressure is pretty much identical:
                        MSS54 (0401)
Name:	Screenshot 2026-01-18 at 4.39.32 PM.png
                        MSS65
Name:	Screenshot 2026-01-18 at 4.39.37 PM.png
                        MSS65 stores rg parameters in a struct which is why there are all of the pointer offsets
                        Build Thread:
