As some of you might have seen on my original post: https://nam3forum.com/forums/forum/m...no-crank-issue
I am struggling with a no-crank condition.
In an attempt to further troubleshoot, I'd like to code the EWS to ignore the clutch switch, following this: https://www.e46fanatics.com/threads/...witch.1313143/
I'm following these steps with NCS Expert (my install doesn't have an "expert profile" but a profile named "default profile", which I assume is the same).
I am changing PARK/NEUTRAL_EINGANG from aktiv to nicht_aktiv, and everything seems to go well, no error or anything, I copy my stuff from the TRC file I have read with CODIERDATEN_LESEN to the MAN file I created blank at the beginning of the process, then I run the SG_CODIEREN job, everything finishes with no error.
But when I run the CODIERDATEN_LESEN again, that parameter is still aktiv. This is driving me nuts, what am I missing? Is the EWS not codable or something like that?
I switched the car on / off, I even unplugged/plugged back the EWS to be fully sure it has powercycled.
