Originally posted by R3Z3N
View Post
Double checking CSL tune conversion/flashing process for MSS54HP non-CSL
Okay, yeah, so FWIW, if you go into the tune and just change all three version strings located at 0xBFB8, 0xBFC8 and 0xBFD8 to match the version of the full binary running on the DME that you're flashing the tune to, that's enough to get MSSFlasher to let you. But, to anyone reading this, obviously, only do this if the tune you're flashing matches the tune version of the full binary you're running (i.e. 0401 tune to 0401 binary). Otherwise this seems like a great way to really f*** up your engine.
I'm also going through this process and want to make sure I've got this sorted out. Can I get a quick sanity check on these steps below
Car - 03 M3 with MSS54
Replace DME with MSS54HP (EWS delete) and wire in IAT / Map sensor
Flash Terras modified BIN via MSSFlasher
Pull partial and send to my tuner (or set Cam offsets / pressure sensor / injector / flap DTCs myself)
Flash updated partial
Car should now run and drive properly + OBD compatible
That will work. But if you're replacing your current DME with an HP, you don't need to modify the binary for the pressure sensor. That's only necessary on non-HP to HP hardware conversions, as the physical sensors on the board are different.Originally posted by Amalgam View PostI'm also going through this process and want to make sure I've got this sorted out. Can I get a quick sanity check on these steps below
Car should now run and drive properly + OBD compatible2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
For the benefit of all of us and Martyn why don't you share the before and after of a file that demonstrates the issue? Or is this something you can't recreate and you think is seemingly random?Originally posted by NZ_M3 View PostI had a look at your file in your attachment and some of the stuff ticked aren't implemented or have been implemented incorrectly. As I have been saying the tool has issues.
What's your email?2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
The Basic XDF does not show a download button, but the Complete XDF does.Originally posted by Kdubski View PostAnyone have issues downloading the 0401 v4 XDF? When I hit download it opens as a new window text document. Any direction would be appreciated.Last edited by Slideways; 06-29-2023, 10:31 AM.
