Originally posted by x Spades x
View Post
MSS5x Binary Modification Tool Update
I think you want to adjust it to so the last light goes off till it hits the first dot?06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Try adjusting it with the arrow keys.Originally posted by r4dr View PostIs there any way to manually edit the throttle response mapping values? I can't get the sliders to be exact values so mine are set to "as close as I can get it" but I think it's messing up my 1%. Someone posted that if both their throttle maps had the same value for 1% the SMG refused to shift from 2 > 1 automatically. I'm having that issue right now with my linear sport map because the closest I could get 1% to was 0.967 or something, and I'm not sure that actually gets computed as a value of 1% for the DME.
Martyn
I think you need to look over this software again, I’ve noticed quite a few bugs with it and have been fixing other’s tunes as a result.
for example, if you do binary modifications via tunerpro or a hex edit tool or apply an already modified file to it and make changes subsequently it does some really weird stuff to the file (makes changes in weird random places and applies incorrect dtc deletions ect).
also it doesn’t work correctly on 0301 CSL software version.
Hey Martyn, what specific damage can occur when running burble/pop with cats? I've got a Euro exhaust setup so that cats are not on the headers if that makes any difference.
Does it ruin the catalyst so it can't effectively clean the exhaustb or will melt the catalyst up and ruin your exhaust that way?2004 Silbergrau Metallic 6MT
