Harness mounting options for street/track car?
    Originally posted by simonnim View Post
    Obioban I just picked up the BK mounts from forum member. What do you run for the belt strap mounting? Right now I'm just using some generic seat mount adapter with the garagistic floor mount. But my seat mount doesn't have a place to attach a belt for clip in or screw in.
    On the inside, the factory receiver. Keeps idiot lights off and the pre tensioner in play.
    On the outside I have sedan sliders— so I use the factory lap belt attachment point, with a clip in adapter that BK makes.
      Obioban ahhh, ok. I'm not on any of those.
      I have https://www.murraymotorsport.com/mur...ts-mur1130-015
      I know, I know..I'm trying to get into the right spot. I'm guessing I need a new seat mount that has a bracket right?
        How are you running that harness with the factory receiver? Is there some belt that schroth sells that can be swapped out? Or did you just grab a buckle and thread the harness through that?
          That’s how I came to the profi 2 ASM. I can run it as a 4 point or 6 point, in either case safely, depending on the requirements of the club in question.
          Bringing this one back.
          Your configuration looks like just what I need. Were the Profi 2 ASM belts long enough out of the box to accommodate the BK R-1246 rear deck mounts, or did you have to order them extra long? Do you use the snap in attachments to attach the belts to the rear deck mounts?
          I am in deep enough that its time for a head and neck restraint. I am considering either a Hans or the Simpson Hybrid. I would be interested to hear what you are using and how you like it.
          Thanks.
          D-O
          Old, not obsolete.
            Thanks.
            D-O
            I use the R-1246 rear deck mount, but I'm tall, so I run the seat pretty far back. If you're average height or short, they're probably not going to be long enough.
            I do use the Schroth clip in attachments, to the R-1246 rear deck mount. Also for the outboard lap belt. Inboard lap belt I have clip into the factory seat belt receiver (like the quick fit does), so I get the benefit of the pretensioner and so I don't get a seat belt light on the cluster.
              Many thanks.
              Guess I will reach out to Schroth and ask how best to measure and determine the length I will require.
              Any opinions on the various head and neck restraint options?
              Old, not obsolete.
                Many thanks.
                I've been using the same Hans device for 20 years now, so no opinions on anything current
                  Many thanks.
                  I use a hybrid device mostly because I instruct - can be used with stock 3pt seat belts.
                  I think a hybrid device provides better lateral restraint at the expense of some forward restraint. It is a little easier to get into the car - doesn't get hung up on a containment seat - and you can turn your head slightly more. But a HANS is easier to put on and more comfortable IMO.
