I have actually no problem with my Dkg
but I found an mss60 from à Dkg of 2010 because my mss60 is bricken
So I need to read the new ISN with MSS60 Flasher and code it into CAS. Make alignment CAS and the car will start and run without problem ?
thanks
MSS6x Flasher - Now released!
You can load a new ZUSB (program/data) with your own VIN if that causes issues. Then code the ECU and go. No additional tasks need to be performed to make it work.Originally posted by steph57 View PostIt’s mean that you can put any DKG control unit in a m3 e92 without coding it ?
Hello, someone has already use an used MSS60 in an M3 E92 with DCT Gearbox ? I'm afraid to buy a new ECU and that the ISN of the DKG will not match with the new ISN in the CAS
No never used before, i used it after the obd fail. No communication always on left or right side. i have 2.6V which come to the MPC but it don't want communicate
Have you already used your Ktag with this ecu before your problem ? If not, check the connections to the bdm port. You must have communication with your ecu whatever the corruption of the intern or extern memory.Originally posted by steph57 View PostNo i can't read anything. No ext no Int flash, it's a 170ELast edited by MpowerE36; 05-02-2022, 09:51 AM.
Hello, thanks for your answer
actually I can’t identify the ÉCU by obd and I can’t read left or right side of the MPC with my ktag
You can't read the CPU memory or the extern flash ? If you just can't read the CPU processor it probably comes from that your injection CPU is censored. The only way to recover it is to uncensor it with special BDM tool and carefully read the "MSS60 research" topic.Originally posted by steph57 View PostHello everybody,
I Flash an e92 m3 with MSS60x flasher with original ecuworx m3 e92 cable
It failed during the RSA ByPass
I tried read with TOOL32 but no connection to ECU.
I have original dump but only a Ktag and i can't read it, i don't know why..
What i can do ?
Hello everybody,
What i can do ?
Yeah ive tried it in both positions with the switch pressed and depressed with INPA, I am getting IFH 0003 data transmission to interface disturbed. Thats when trying to open the engine ecu.. I am starting to think the cable is dead because I have tried everything else apart from the IP address change inside ediabas.ini which I have heard isnt needed anyway..
The led doesnt come on at all but the cable is recognized in device manager as normal and I am able to change port settings etc. Am I doing something wrong? I dont think I am because I have never had such issues before on other cars and the fact that mss6x flasher is basic when you have 10flash.PRG etc in the ediabas folders etc it should just read the ecu easily... Im stumped.
Do you have a switch K / DCAN on your OBD cable?Originally posted by mrvex View PostGuys,
I am a little lost here, I have installed BMW tools from BMW Geeks and also using the cable to match and followed all instructions, for some reason, with the flasher and with INPA, I am getting no connection to the car, flasher says unsupported/unknown and INPA just wont connect.
I am trying to connect to an E9X. I have turned down the latency to 1 also obd.ini is set at comport 1 as also in my device manager. Still nothing, the switch on the cable does this need to be pressed down or is that for older bmws?
Also this Dcan.exe application, do I need to use that in the background to archive a DCAN connection? Im lost... Also is there an LED indicator on the Bimmergeeks cable? Because that isnt coming on either.
Thanks in advance.
Guys,
Thanks in advance.Last edited by mrvex; 04-14-2022, 12:03 AM.
