Lets see your e46 m3 thread
    Originally posted by Kiser.mt View Post
    Tail of the Dragon
ID:	138076 Click image for larger version
ID:	138077 Click image for larger version
    Nice looking ride man. What specs are those E88's if you don't mind me asking?
      Thanks! Specs: 18x10 +21mm square with 265/35 RT615k+ and 12mm rear spacers.
      06' Interlagos Blue ZCP 6MT // Instagram
        Tail of the Dragon
        Looks great! Reminded me of my ZCP that I had years ago.
            Tail of the Dragon
            whoa. What spring rates are you running? It’s like a mm away from the fenders.
            Just some old shitty cars.
              Tail of the Dragon
              This is perfection.
                Thanks! and for coilovers I'm running Fortune Auto 500s with swift springs - 10k front and rear
ID:	139563 Click image for larger version
                  Tail of the Dragon
                  Wow, beauty!!!!!
                    May I ask how you came to the decision of 10k in the front?
                      Was thinking the same thing. Haven't seen that spring rate choice before.
                        Well, if your front end is that low, you're gonna need a pretty stiff spring to keep from bottoming out.
                          I just checked my order history from FA - typo - I'm running 10k front and 12k rear. Their standard off the shelf rates for the E46 M3 is 8k/10k. Swift spring rates always run softer compared to competitors.
                          but I can't recommend swifts enough on any coilover set up. If you took my M3 for a drive, you would assume I'm running a GC set up with 400lb springs - it's not harsh at all.
                            Click image for larger version  Name:	img_8469.jpg Views:	48 Size:	143.2 KB ID:	139563 Click image for larger version  Name:	img_8466.jpg Views:	49 Size:	110.1 KB ID:	139564
                            Do you even [front] camber bro?
                                Did a little photoshoot with the new daily we picked up for the fiancee. '04 E53 with only 80k miles. It's the same bolt pattern and center bore as the E46 so I put some a/t tires on my staggered ZE40s off the M3 and threw them on. It's in super good condition...
ID:	141064 Click image for larger version
ID:	141065 Click image for larger version
ID:	141066 Click image for larger version
ID:	141067 Click image for larger version
