Lets see your e46 m3 thread
    Did a little photoshoot with the new daily we picked up for the fiancee. '04 E53 with only 80k miles. It's the same bolt pattern and center bore as the E46 so I put some a/t tires on my staggered ZE40s off the M3 and threw them on. It's in super good condition...
ID:	141064 Click image for larger version
ID:	141065 Click image for larger version
ID:	141066 Click image for larger version
ID:	141067 Click image for larger version
    Nice find👍 If you don’t mind how much did you purchase it for?
      8k. And honestly for the condition it's in I'm happy with that price. The interior is immaculate and after a paint correction the exterior looks amazing too. Not one ding. Mechanically the only thing it needed was CV joint boots. I'm installing an avin avant 4 next week to bring it up to modern tech inside.
            Originally posted by sdmcoupe View Post
            More pics please Love Phoenix Yellar.
                Originally posted by Kiser.mt View Post
                I just checked my order history from FA - typo - I'm running 10k front and 12k rear. Their standard off the shelf rates for the E46 M3 is 8k/10k. Swift spring rates always run softer compared to competitors.
                but I can't recommend swifts enough on any coilover set up. If you took my M3 for a drive, you would assume I'm running a GC set up with 400lb springs - it's not harsh at all.
                I ran the exact same set this past season with the same rates, minus the swift springs. They were extremely comfortable and those digressive shocks really handle the bumps well.
                  The sun came out after a rainy track day. The car is simply a joy to drive. 🤗
                    Just curious how guys with CSL front bumpers find brake temps and and how quick is pad/rotor wear since you don't even have the non-CSL brake air ducts for airflow.
                    Youtube DIYs and more
                      I've been passively wondering the same thing.
                      Also, are those E88s?
                        Not an M3, but very similar and different at the same time. It does have a few interesting mods that have made it rawer and more of an experience to drive; I still need to do a few more mods to finish her up.
                        Engine
                        Karb CSL Intake
                        Radiator Cover Roundel
                        ECS Exact-Fit Vanos High-Pressure line
                        ///M Oil Filler Cap
                        Remus Exhaust
                        Euro Headers
                        DKF 200cell Cats
                        Epic Alpha-N Tune
                        Turner MAF Delete Harness
                        Vibra Technics Motor Mounts
                        Chassis
                        Brembos Front & Rear
                        Braided Steel Lines
                        OE Strut Tower Brace Bar with OE & Custom Covers to hide hardware
                        Textar Pads Allround
                        17.5mm Rear Spacers
                        Syncro Design Work RTABS
                        H&R Coilovers Struts & Bilstein B8 Shocks
                        250# and 600# Linear Springs
                        Camber Shims
                        Shorter Bump Stops for extra bump travel
                        RE Rear Shock Mounts
                        Exterior
                        Laser-etched Headlamp Lenses
                        Skyer Hatch Spoiler
                        OE Style 216 Motorsports Wheels
                        Rear Foglamp Retrofit (EU Switch + Coding)
                        Color Matched Bumper Reflectors
                        Interior
                        Blue Cluster Dials
                        Vinyl Wrapped Interior Trims
                        OE Chrome Radio Knob
                        M Performance Pedal Set w/Footrest
                        Tall Weighted Shift Know
                        Autosolutions SSK
                        BlueBus
                        2022 Plans
                        4.1 Final Drive Ratio
                        CSL Front Sway Bar
                        225# Front Springs
                        Rear Koni SA Shocks (maybe)
                        Now onto some photos I like, not real good, just nice.
                        Click image for larger version  Name:	IMG_0127-2.jpg Views:	0 Size:	159.1 KB ID:	145647
                        Click image for larger version  Name:	IMG_E1503.JPG Views:	0 Size:	126.8 KB ID:	145648
                        Click image for larger version  Name:	IMG_0716.JPG Views:	0 Size:	180.7 KB ID:	145649
                        Click image for larger version  Name:	IMG_0752.JPG Views:	0 Size:	289.1 KB ID:	145650
                        Click image for larger version  Name:	VFNK9281.JPG Views:	0 Size:	161.8 KB ID:	145651
                        Click image for larger version  Name:	IMG_0215.jpg Views:	0 Size:	105.7 KB ID:	145655
                        Click image for larger version  Name:	IMG_1098.JPG Views:	0 Size:	109.0 KB ID:	145652
                        Click image for larger version  Name:	IMG_0713.JPG Views:	0 Size:	152.1 KB ID:	145657
                        Click image for larger version  Name:	IMG_0308.JPG Views:	0 Size:	75.4 KB ID:	145653
                        Click image for larger version  Name:	IMG_0417.JPG Views:	0 Size:	126.6 KB ID:	145656
                          I'm going through a set of PFC08s up front once a year (about 8 track days on this car) with my Stoptech ST40s. Two of the 3 tracks the car has been on this year are hard on brakes. The Stoptech rotor rings have lasted about 15 days so far and look to have normal wear and heat checking. No concerns with these for the next 5 track days or so, but I did crack a set of RacingBrake replacement rings prior. M3 Track Tools & Pinnacle Motorsport just released a new brake duct kit that uses ducts on the lower A-arms, which will be helpful for us CSL front bumper owners. I still street the car a lot, but will likely get this if I decide to track the car more frequently next year.
                          Click image for larger version  Name:	Screen Shot 2021-12-27 at 10.37.06 AM.png Views:	0 Size:	763.8 KB ID:	145665
                          Click image for larger version  Name:	Screen Shot 2021-12-27 at 10.37.41 AM.png Views:	0 Size:	926.0 KB ID:	145666
                          Yep! They're 18x10 square E88s.
                              😗 Looks brand new, nah, better than brand new.
