Originally posted by heinzboehmer
CA/LA Smog
Originally posted by sev View Post
man i hope thats the case. I have to smog right now and I have my throttle mapping, shift lights, etc.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Oh shit this software thing goes into effect Jul 19. I'll do what I can to get my car smogged this week. That will at least buy me two years before I have to get it smogged again.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Unfortunately, some more digging made me think that's wrong. Probably wise to flash back to stock just to avoid any potential hassle. You can flash your changes back on afterwards.
Hey everyone,
I've been digging through my old files when I got my first canned tune from Randy @ Epic for stock airbox, euro cats and headers configuration and came across this information when I did the preliminary ECU scan for him:
Vehicle Manufacturer Ecu Hardware Number : 7842981
Vehicle Manufacturer Ecu Software Number : 7842979
Vehicle Identification Number :XXXXXXXXXXXXXXXXX
It would be nice if some of the well-known tuners can chime in.
does doing a partial bin dump/write eat up flash slots? i really dont want to deal with that. arggghhh2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by heinzboehmer View PostOh shit this software thing goes into effect Jul 19. I'll do what I can to get my car smogged this week. That will at least buy me two years before I have to get it smogged again.
Originally posted by skristedja View Post
What's your source on this? I'm going through the regs right now and haven't seen this, only saw it was proposed2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
You get like 30 flashes, but each one uses two slots iirc, so more like 15.
I really don't see how modifying a little code is going to change the serial numbers. As long as the ECU is your original, should be fine I would guess.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Sure, if the CVN and CAL ID are just constants stored in the firmware (serial numbers, hardware/software numbers, etc), then getting past these checks is trivial.
However, the documents posted make it seem like the CVN is actually a checksum. This is a mathematical operation that is performed on the entirety of the software to produce a number. So yes, even if you change a single bit, the checksum will change too.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
The e46 may be exempt. Manufacturers were not required to submit CAL ID and CVN info for 2007 and prior years.
Page 6 of http://ww2.arb.ca.gov/sites/default/...og/msc0623.pdf
CAL ID & CVN
Section (g)(4.7.4) of the OBD II regulation requires manufacturers to submit CAL ID and CVN information. A template titled “CAL ID and CVN Data” is provided in this Mail-Out as Attachment E. For 2008 and subsequent model years, manufacturers are required to use the Microsoft Excel electronic template provided on the ARB website http://www.arb.ca.gov/msprog/obdprog/obdprog.htm for reporting and electronically submitting CAL ID and CVN data to ARB.
heinzboehmer has it correct.
Everyone needs to realize that if the CVN is indeed a checksum, which is how it reads, rather than a simple stored value then any modification to the DME will cause you to be flagged as your CVN would then be incorrect. I can't believe CVN is a simple stored value because it's usefulness as a software modification check would then be zero. It almost assuredly is a calculated value. If you aren't a computer guy your thinking what do you mean calculated? A little formula using the OE software engine parameters as inputs will be used to produce a value. Change an engine parameter, change the value that is produced by the calculation.
terra do you know if the CVN is a calculated value or stored value?Last edited by oceansize; 07-13-2021, 12:23 PM.3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
