Hi Ted, I just filed a bug in github, I found several issues in my Z4M. I wonder if these are known, or some may be "normal". I am listing those below
- The settings menu is not persistent, the bluebus continues to return to the "main page"; to adjust settings you need to do it very quickly before it kicks you out. This means the settings need to be adjusted quickly and blindly
- When autoplay is off, the bluebus constantly pauses music, if enabled (on), you cannot pause it (it resumes playing). Also, you can perceive audio coming up and down as the system pauses and then auto-plays again.
- When connected to the phone and streaming musing, if I try to use the AUX mode to reproduce music, it is as if the phone stays in Bluetooth mode and pause, so no sound comes out.
- When in Bluetooth mode, the clock button does not display the time, even when metadata is off.
- When the car is turned off (key in 0 position) the musing stops, but the radio display remains on, I have not timed for how long until it goes to sleep.
