S54 running (slightly) rich
    I’m dealing with this exact same issue. However I have reason to believe that my cats may be also going bad.
    I’m planning on getting all o2 sensors replaced, and then remeasuring the o2 voltages as it appears my Bank 2 post cat voltage is fluctuating at the same rate as my pre-cat.
      When the post sensor voltage follows the pre sensor voltage, that does indicate a bad cat. As long as you do not have O2 sensor codes, the sensors should be working correctly.
      BMW does suggest 100k mile service interval for O2 sensors.
      Click image for larger version  Name:	Service.jpg Views:	0 Size:	227.9 KB ID:	330198
        1 of post cat 02's is dead, i do not think that effects LTFT
        I have a slight stumble at start up from time to time, i am thinking injectors are shot
          Back on the old forum pre-2020 I had some long thread about chasing lean LTFTs and seemingly less than ideal fuel economy, threw basically every part one could throw at the car, it never changed anything. I wonder to what extent LTFTs on some engines are the way they are simply due to manufacturing tolerances on the heads, valves, etc?
          Car's modified and tuned now (whereas was bone stock back when I was chasing this down), so I figure it's not really meaningful to compare current LTFTs to the ones that I was trying to fix before.
          I kind of wish my old thread still existed to try and dissuade anyone from getting too obsessed with fixing this. Then again, if people are able to make discoveries about how to diagnose these issues that I missed, I'm interested in seeing it happen!
            No updates from me. I just live with it. Car is a weekender at best. It runs perfectly, pulls well, doesn't audibly ping. I don't have an idea of fuel economy but it's not drastically bad.
            These are really "rich" LTFTs. DME is reducing the amount of fuel because it think it's too rich.
            Injectors was probably a next guess for me, but given it doesn't really seem a problem, I'm hesitant to chuck money at it.
              Originally posted by Shonky View Post
              I don't have any fix, no.
              I did throw a brand new Bosch MAF from FCP as I was doing an order at the time. That did not fix it and I'd have to check the numbers but it ended up about a percentage point worse than I had before. ie slightly richer again. Im still running that new MAF after many months. I might revert to the old one without a clear and see if the values come up a small amount.
              The MAF graph below looks so wrong with very high value in g/s at idle. I like to see the MAF data at hot idle, should be less than 5g/s
                Car's modified and tuned now (whereas was bone stock back when I was chasing this down), so I figure it's not really meaningful to compare current LTFTs to the ones that I was trying to fix before.​
                With proper parts installed, even a modified engine should have proper LTFT as the DME continues to adjust the injected fuel for a proper pre-cat o2 reading.
                Post the hot idle data of pre-cat O2, MAF, rpm, engine temperature and I will tell what's going wrong/right. Better to use OBDFusion app and upload the csv file to datazap.me for graphing the data, then post your datazap link here.
                Edited: datazap.me, not datazap.net
                  This was a long time ago. It wasn't all idle. There's no way you can read the g/s at idle because of the graph scaling.
                  From memory it is high 4.xx g/sec at warmed up idle.
                  Post the hot idle data of pre-cat O2, MAF, rpm, engine temperature and I will tell what's going wrong/right. Better to use OBDFusion app and upload the csv file to datazap.net for graphing the data, then post your datazap link here.
                  I will do this in the new year​ and await your diagnostic skills.
                    I’m looking forward to see what comes of this!
                      Same ! Thanks for the updates, hope more memebers chime in with there LTFT from inpa on my other thread so we can all compare
                      Who has widebands installed? can anyone post AFR figures for us ?
                      Anyone else with rich LTFT got the cough at start up ?
                      few sellers on eBay throwing injectors around
                      What about logging with testo ?
                        Mine starts "on the button" every time.
                        Previously it did occasionally not fire first time seemingly regardless of crank time. I'd stop cranking after a second or two (long enough to know it probably wouldn't fire), cycle key and second time would be instant. I don't know what fixed it but it *seemed* to go away around the time I did the VANOS. There wasn't anything wrong and it passed the DIS test prior, I just did the Beisan kit. I've seen the odd report of similar but no explanation.
                          Other than the P0430 code I’m getting, and the similar LTFT numbers, my car runs like a top. Go figure…
                            Low cat efficiency will fail smog check; what is your plan for passing smog?
                            Post the datazap.me link here and we will take a look of what's going wrong.
                              I wish I could see that old thread as someone in your previous shoes! I replaced my alternator the other day and messed up and broke an original hose clamp putting my eventuri intake back on. Put a home depot hose clamp on it and it must not have worked so well. Car fired up and sounded like crap. Multiple misfire codes. Got a replacement hose clamp and put it all back together and I can feel the car "shuddering" a bit. I did other stuff while doing the alternator like a MAF clean (with MAF spray) and cleaned the eventuri filter.
                              So while chasing this shuddering/slight vibration down I noticed I'm lean on the LTFT - somewhere in the 9s or 10s (using obdfusion, I think it would be like 1.09 or something in INPA -- too lazy to get the laptop for it all). Smoke tested it, checked fuel pressure, already have a new fuel filter, charted the pre cat o2 sensors -- probably a lot of the things you did when you were chasing it down. The car still does shutter / vibrate (can feel it in my seat -- it's not engine mounts - did those last year), and I can watch the idle slightly bounce around (it's usually normal, but during these brief shuddering fits it does drop a bit more). I thought for sure it would be my original fuel pump (71k miles), but the pressure gauge test tells me it's just fine.
                              I hate the feeling of that shudder/vibration - but like you, I'm just gonna drive it and see what happens. The STFT's are all fine, it's just that long term one is off. I'm not ready to throw the parts cannon at it yet.
                              Do you remember - when you were chasing this down, did you feel a slight shudder vibration at idle or when bringing up the rpms in neutral?
                                I has been waiting for 7 month for the data log…
