What oil?
Name:	Baby Come To Bed Oil.jpg
    MVP Track Time
      I'm in this picture and I don't like it
        Following this thread got me reading post by post 🤣
        Liqui Molly 10W 60 via FCP Euro, have been using it for 10 years on the same //M3
        BMW ///M3
        Dinan | Eonon
        BMW S1000rr
        Dieci83 | 4Racing | OneDesign | D.I.D | R&G | TST | PSR | ASV |
        TWM
          Same here, started with Castrol first 2 years then switched to LM 10w60 per my race shop.
            LM 10W-60, FCP. If shipping the old oil back is "a little annoying" you might be "a little lazy".
              Where's icecream? I remember he spun a bearing after switching from TWS. Might have been coincidence, but it seemed to be the only thing that changed
              This is true, they did spin after the first change with the twin power stuff. However, given how fubarred the bearing was, how little the crank was damaged and how hard I drove it with the damaged bearing, I think the oil did extremely well. It was coincidental it went out with that oil. When it first started to tick I didn't think it was a bearing (or anything that serious) so I still hit redline a few times and the engine didn't grenade itself, impressive if you ask me.
              oh and hello everyone
                  Running BMW 10W-60 + Ceratec. Nothing like free from FCP.
                  ‘02 TiAg/Impulse Slicktop
                    Ceratec is not free ;-)
                      Ah I guess I was remembering things wrong. For some reason I thought you had traced it back to the oil.
                        Cheaper on Amazon too.
                          Also I know this is a new forum, but on m3f we agreed on no using any additives, if I remember correctly :-)
                            Very impressive indeed. My piston disappeared when a bearing welded itself to the crank.
                            And welcome back!
                              Ya, no snake oil
                                Interesting. What Motul did you use in the trans? And I'm assuming Gear Competition 75W-140 in the diff, yeah?
                                Sorry for the late response. Yeah, gear comp was for the diff. I used Multi DCTF for the trans.
