What oil?
    What about this oil for the street ?
    if you're going to use Penrite why not use 10 tenths R 15W-50 or 10 tenths premium 10W-60?
      Amsoil now has a 10W60 available.
      [ATTACH]n295688[/ATTACH]
      What is consensus on this oil?
      Typically most of the independent shops i went to used Liqui Molly, but my last oil change the indy shop used Amsoil. Still not sure what to expect, but all seems fine so far.
      From what I heard, Amsoil is a really trusted brand.
      My last 2 oil changes i sent for Blackstone oil analysis so ill see what comes back with Amsoil, when I change the oil again.
      2004 M3 6MT |Eventuri Intake|
        IMO, it's pretty telling that Penrite won't claim more than LL-98 performance levels from those. At least the HPR 10 is claimed to be at LL-01 level – still not enough for the S54, but better than LL-98.
        Those 10 Tenths oils seem to be formulated for motorcycles and some track/race cars, not street cars. I don't see the point. Even if they reduce wear vs. other oils, the reduction will be so slight you'll never notice. That may or may not come with increased friction (and thus heat, which – oops – might increase wear in bearings and rings). The only thing that's certain is that they'll accelerate poisoning of the cats.
        2008 M3 Sedan 6MT
        2012 Mazda5 6MT
        A few Volvo parts
          Why did you bump this thread? That’s so evil 😈
            I Bumped it sorry man, i wasn't starting a new oil thread,
            i can't find much 10W60 off the shelf here in Australia, It's all special orders or roll the dice online,
            Penrite is easiest to source cause it's made here
            After having the head off, and witnessing those brown stains, and rock hard seals, i am not convinced in using TT or Edge
            Here is the 10 Tenths someone mentioned
              If I saw brown stains and rock hard seals, I'd suspect overextended oil change intervals (too long for how the car was used) and/or not driving enough.
              2008 M3 Sedan 6MT
              2012 Mazda5 6MT
              A few Volvo parts
                Cheers man,
                Was there any conclusions on the label change for Edge ? i can get this ordered in locally
                  Cheers man,
                  They have had a few label changes. It is all the same 10W60.
                  Since you just had the cylinder head off, I'm guessing you had it cleaned by your machine shop. If that is the case, the head will not turn that dark gold color if you do the 7500 mile oil change interval.
                    Thanks heaps sideways
                    The service history shows oil changes ( converted them to miles )
                    1,360
                    9,280
                    19,150
                    30,000
                    38,000
                    46,600
                    57,100
                    62,100
                    74,500
                    81,000
                    93,200
                    100,600
                    104,000
                    108,100
                    110,000 = Head gasket
                      1360
                      9,280
                      19,150
                      30,000
                      38,000
                      46,600
                      57,100
                      62,100
                      74,500
                      81,000
                      93,200
                      100,600
                      104,000
                      108,100
                      Was the head gasket failure accompanied by overheating? That could explain some of the brown staining (in addition to some of the 10k+ oil changes).
                      2008 M3 Sedan 6MT
                      2012 Mazda5 6MT
                      A few Volvo parts
                        M3s are usually low mileage cars. If you consider time as well, 14 oil changes over 20 years? Need to change it at least every year. Shiet, my 2011 E90 M3 is almost 14 years old. About to get its 46th oil change.
                          38,000
                          46,600
                          I'm no expert, but isn't 13,840 KM (8,600 miles, and more on some of them) quite an excessive oil change interval?
                            Depends on the usage. If the engine is in perfect running order, with high quality fuel, doing few cold starts and a lot of easy highway miles, I can't see a reason you couldn't go that long. But there's really no way to tell without oil analysis (and even then it's sketchy).
                            Personally, I'd never run it that long regardless of usage.
                            2008 M3 Sedan 6MT
                            2012 Mazda5 6MT
                            A few Volvo parts
                              Thanks for answering again
                              Sorry man, I only picked up the car at 110k miles
                              When i pulled the thermostat, It was dated 2001, and the car ran at the 1st dot ( cold ), so i am not sure if was over heating prior
                              Here in Australia, all local Indy shops, Sticker the windscreen with a, ( Oil change due in 6 months or 3100 miles, Which ever comes first ). , As I do all the work myself, i seem to like those intervals with the money i save, Only the main dealers here are the 1s that insist on the extended intervals
                              What are your local indy guys like over there with interval changes in NA?
                                *PSA*
                                Talking about oil weights by using terms like 5w50 or 10w60 is almost useless. Just like tires - A 265 Michelin PS4S can be wider than some ling ling 275 tire.
                                Castrol TWS is called a 10w60, but it acts like a heavy duty 40 weight from my research. Then there's something like Liqui-moly 10w60 with a CST of 26+ at 100degress, which is about the highest I've ever seen, much higher than castrol or other 10w60s.
                                The "redline 5w50 instead of castrol 10w60" argument for S54/s65/s85 has gotten popular, but is redline lighter than castrol?
                                Well, 1st formula of redline had HTHSV rating of 5.9, newer formula is 5.0. Castrol is 5.3! Barely any difference. "ReDlInE is bEtTer in the CoLd!" Well, RL 5w50 has a cold pour of -45 and Castrol's is -39 so no.
                                Viscosity, Kinematic 100°C of Redline is 21, Castrol is 22.7, almost no difference.
                                You cannot conclude that redline is better for cold starts than Castrol just because Redline says 5w50 on the bottle and Castrol says 10w60.
                                Haven't even discussed additives. Perhaps Redline is low on additives because their product is meant for race cars. So even if redline and castrol were neck and neck in terms of viscosity and resulting oil pressure etc, Castrol could still be a better choice for most (Street cars) due to better/more additives.
                                Or maybe you have cats and don't want a race oil high in ZDDP? Castrol has other anti-wear properties that don't damage cats.
                                Good Info, Can you please look into these oils for me ? Tbonem3
