Originally posted by usdmej
View Post
CPV oring keeps tearing
Originally posted by Chanman1029 View PostGonna try to find a local store that sells gaskets in bulk, I’ll report back with my findings.
If you have another new cpv with stock oring they can measure it for you.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
You have the specs above in post #17. Go to your local bearing place, grainger, mcmaster etc and buy one for .25 cents.
Originally posted by Chanman1029 View Postseems that the threads going into the block have to rough spots.
Originally posted by Chanman1029 View PostSome of the threads seem to have an oil journal cut through them, and this is what seems to be tearing my o rings when I tried to screw it in all the way..
This is similar to the oil filter cap O-ring, that during install, make sure the o-ring is lubed with grease, screw the cap down slowly and make sure the O-ring is not jammed between the cap groove edge and the oil filter housing top edge. Of course you need to compare how much your O-ring protruding out compare to this photo.
Your issue is the O-ring was jammed between the block hole edge and the CPV groove edge.
Some of the threads seem to have an oil journal cut through them, and this is what seems to be tearing my o rings when I tried to screw it in all the way. I ripped one gasket and installed the second one without tearing it, however the cpv is not fully inserted like many of the DIYs show it to be. And advice? I’m wondering if I will need to file down the edges of the sharp threads or something
what is going on here?2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Originally posted by lemoose View Postwhat is going on here?2008 M3 Sedan 6MT
Slicktop, no iDrive | Öhlins by 3DM Motorsport | Autosolutions | SPL
2012 Mazda5 6MT
Koni Special Active, Volvo parts
- Likes 2
Originally posted by Chanman1029 View PostPretty sure that both of them were the ECS Viton one. I can confirm atleast one of them was. They didn’t seem to be excessively big, looked normal to me. This sucks. I think I’m gonna go buy an assortment of 16mm x 2mm gaskets, and get rogue with this thread repair, at this point the only reason I’m concerned is about metal shavings, I haven’t even started my motor yet since its had a full rebuild. This is literally the only thing stopping me from starting the car.
S54 Hi-Temp Cooling System Orings
Complete set of Hi-Temp Silicone and Viton O-rings for the Entire S54 Cooling System. Also comes with the Power Steering, SMG Reservoir and Expansion Tank Cap O-ring's! Replace the factory Buna orings with higher quality Hi-temp Silicone and Viton O-rings. These O-rings have higher temperature rating and more resistant to
Originally posted by mpower22 View PostThanks George Hill, unfortunately my post is hidden in a section away from the main classifieds so most people on here don't even see or find it, but the link is always in my signature.
BTW it shows "Banned" under your avatar?
Member Services
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
ECS strikes again! I had an issue buying orings and a new water pump from ECS. The two orings they sent for the small water pipes under the water pump were two different sizes. One was a 16mm and the other was a 15mm, they are both suppose to be 16mm's. So close in size I didn't notice it upon install. This caused one of the pipes to not seal properly and introduced air into the system, I had to tear apart the entire cooling system looking for the problem, all caused by the wrong sized oring sent by ECS! This led me to put together the Hi-Temp Oring sets for the M3 Cooling System.
My avatar says banned or the other guys?
Originally posted by Chanman1029 View PostMy avatar says banned or the other guys?TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
