S54 oil pump chain
    Anyone else have success R&R'ing the timing cover without head removal? Mine is already leaking but I suppose that could be made worse.
    BMW's repair instructions require removal of the heads. So if you have a dealer do the work, they will remove the head. Say what you will about BMW, they are thorough with their repairs and BMW wants to minimize comebacks. You can remove the cover without removing the head, you run the risk of the head gasket leaking around the timing chain overhang. Honestly, I think you'll be OK on a well-maintained engine or at least have a much higher chance of not having an issue.
      I did it without removing the head. Just loosened all the bolts, tapped on it with a hammer and it came off the front. On reinstall, I carefully cleaned the gasket and interfaces and used a RTV sealant between gasket layers as well as between timing cover and gasket, and it slid back in no problem. Snug up the bolts incrementally so it pulls it in and up towards the head little by little into the corner. Been about 7k miles, no leaks, no issues.
        Thanks for the confirmation guys, it sounds like it's not worth the trouble. I was just hoping that when I was down there for rod bearings it could be changed, but I suspected it was not possible since no one does it as common practice.
          Only reason I had to do it was because my timing chain guide broke during install. The chain was perfectly fine like new. Not a wear item.
            I was just hoping to do the tensioner because it looks like the chain gouges the pickup tube over time.
              I want to do the tensioner during RB service and since my timing cover already leaks I think I am just going to go for it and glop RTV on the HG.
                Yeah my tensioner appeared fine, but during the rod bearing job, I had pushed it out of the way and it slipped off my finger and slapped against the chain, and shattered. That was frustrating... what was already a big job turned into a bigger job with timing cover + front main seal, making custom tools to do that job properly, etc.
                  Lol, I benefitted from that frustration, your special tool worked great on my S85 and I'm sure will on the S54.
                    People back to the main topic about this oil pump chain scoring, I too have the same issue noticed when doing the rod bearings scoring on oil pump pick up tube, is this common ? what can we do ?
                      Add second spring plate to the oil pump chain tensioner but that requires the front timing cover to come off.
                      EDIT: I AM WRONG, see my DIY: https://nam3forum.com/forums/forum/m...ng-chain-cover
                        Can anything be done without removing timing cover ? Allegedly a person on insta stated that you can change the tensioner from the oil pan access
                          I'm all ears if there is a way to do it.
                            Tigm3 An additional leaf spring can be added without removing the timing cover. I just did it earlier. I took some pics and will write a DIY soon. Essentially you insert the new leaf under the 2 retention tangs until the bottom of the spring hits the 1st spring retaining rib. Then using a pick, you lift up the bottom of the spring and push it in farther until it is past the 1st retention rib.
                              jayjaya29 I would appreciate that greatly as im still there at it. It is even possible to remove the oil pump chain guide tensioner with long pliers and you will need to shave the new one in a bit to fit. It's hard but possible.
                                Been seeing here and there that adding an additional leaf spring to the oil pump chain tensioner can prevent the chain from contacting the front pickup tube. I have not seen any information on how to actually do it without removing the timing chain cover. Doing rod bearings so I decided to see if it was possible to fit in a
