Originally posted by Cubieman
S54 oil pump chain
BMW's repair instructions require removal of the heads. So if you have a dealer do the work, they will remove the head. Say what you will about BMW, they are thorough with their repairs and BMW wants to minimize comebacks. You can remove the cover without removing the head, you run the risk of the head gasket leaking around the timing chain overhang. Honestly, I think you'll be OK on a well-maintained engine or at least have a much higher chance of not having an issue.
I did it without removing the head. Just loosened all the bolts, tapped on it with a hammer and it came off the front. On reinstall, I carefully cleaned the gasket and interfaces and used a RTV sealant between gasket layers as well as between timing cover and gasket, and it slid back in no problem. Snug up the bolts incrementally so it pulls it in and up towards the head little by little into the corner. Been about 7k miles, no leaks, no issues.
Only reason I had to do it was because my timing chain guide broke during install. The chain was perfectly fine like new. Not a wear item.Originally posted by chris719 View PostThanks for the confirmation guys, it sounds like it's not worth the trouble. I was just hoping that when I was down there for rod bearings it could be changed, but I suspected it was not possible since no one does it as common practice.
I want to do the tensioner during RB service and since my timing cover already leaks I think I am just going to go for it and glop RTV on the HG.2004 Silbergrau Metallic 6MT
Yeah my tensioner appeared fine, but during the rod bearing job, I had pushed it out of the way and it slipped off my finger and slapped against the chain, and shattered. That was frustrating... what was already a big job turned into a bigger job with timing cover + front main seal, making custom tools to do that job properly, etc.Originally posted by chris719 View Post
I was just hoping to do the tensioner because it looks like the chain gouges the pickup tube over time.
Lol, I benefitted from that frustration, your special tool worked great on my S85 and I'm sure will on the S54.Originally posted by cobra View Post
Yeah my tensioner appeared fine, but during the rod bearing job, I had pushed it out of the way and it slipped off my finger and slapped against the chain, and shattered. That was frustrating... what was already a big job turned into a bigger job with timing cover + front main seal, making custom tools to do that job properly, etc.2004 Silbergrau Metallic 6MT
Add second spring plate to the oil pump chain tensioner but that requires the front timing cover to come off.
EDIT: I AM WRONG, see my DIY: https://nam3forum.com/forums/forum/m...ng-chain-coverLast edited by jayjaya29; 09-26-2025, 07:48 PM.
Tigm3 An additional leaf spring can be added without removing the timing cover. I just did it earlier. I took some pics and will write a DIY soon. Essentially you insert the new leaf under the 2 retention tangs until the bottom of the spring hits the 1st spring retaining rib. Then using a pick, you lift up the bottom of the spring and push it in farther until it is past the 1st retention rib.Originally posted by Tigm3 View PostCan anything be done without removing timing cover ? Allegedly a person on insta stated that you can change the tensioner from the oil pan access
Oil pump chain tensioner additional leaf spring DIY (w/o removing timing chain cover) - NA M3 ForumsBeen seeing here and there that adding an additional leaf spring to the oil pump chain tensioner can prevent the chain from contacting the front pickup tube. I have not seen any information on how to actually do it without removing the timing chain cover. Doing rod bearings so I decided to see if it was possible to fit in a
