Possible Head Gasket Failure
    Originally posted by SteelGreyM View Post
    You can see the small piece of head material missing from between the cylinders. If you ignore it this will only get bigger. Do not do what I did.
    I remember that thread. Still baffled by how the head looks at cylinder 1.
    You ever figure out what caused those marks on the head? Almost looks like something solid was bouncing around in there.
      Yep! Turns out 10k miles of detonation will do some damage to your pistons! Imagine a piece of metal flinging around at 8k rpm πŸ˜†
        THREAD UPDATE:
        I'll be yanking off the head tomorrow morning, everything is ready to go, just yanked the camshafts off tonight and prepped everything.
        After reading more and more I'm super nervous about the head being marred so bad, it's unrepairable. I called a local engine machine shop, Star Machine in Emeryville and got an appointment on Wednesday. Guy is super knowledgeable about the S54, he said they're prone to cracking so we'll start with a pressure test and if all is good we'll go from there.
        If I decide to hot tank, what components should I leave in the head?
        Will update thread once I pull off the head, I'm praying it doesn't look like SteelGreyM πŸ˜‚
        Sent from my Pixel 5 using Tapatalk
          Best of luck!
            Nice work, you got this, hope all goes as smoothly as possible.
              UPDATE:
              Looks like my and everyone else's suspicions have been proven accurate, blown headgasket between cylinder 2 and 3.
              Upon pulling the head off, take a look at the block and the head and let me know your thoughts? Doesn't look like any damage on the head at all, do you all suggest I still take it to get decked?
                I think the most is .005 to be removed. Are you doing any upgrades while you're in there? PM sent. Good luck.
                  Yeah a light skim is what I'm thinking, just to make it clean and even.
                  Upgraded the Vanos unit 500 miles ago to all Besian Systems, with a nice Ceracote on it, done by a member on this forum. I also took the time to buy a Dr. Vanos oil pressure line, should look gnarly with everything cleaned up.
                  Haven't done any upgrades otherwise to be honest, I was thinking about internals in the head but that would be at a later date, I just want the car back to baseline. Now I know I can do this sort of job, refreshing.
                    Any tune on the car?
                      I just went through something very similar w/mine not too long ago, except mine was due to spitting a shim…which resulted in a bent valve. Had to R&R the head & re-install everythingβ€”UUGH! It's not super difficult, just time consuming! Make sure that you chase all of the head bolt threads in the block, and use the proper torque technique/sequence. ALSO, DON'T FORGET TO INSTALL THE FOLLOWERS BEFORE INSTALLING THE HEAD!
                      Click image for larger version  Name:	954E5049-22EC-4D18-B68C-662EAF58A0B9.jpeg Views:	0 Size:	136.2 KB ID:	146491 Click image for larger version  Name:	170CC930-FCF7-4E9D-A5FB-F79B8FA1DFC5.jpeg Views:	0 Size:	143.8 KB ID:	146492 Click image for larger version  Name:	CFCB9C10-07EC-42B6-8D86-7A8CB0279592.jpeg Views:	0 Size:	126.7 KB ID:	146493 Click image for larger version  Name:	E7BD24B7-E3C0-46FF-AE14-5C4573E82790.jpeg Views:	0 Size:	158.0 KB ID:	146494 Click image for larger version  Name:	5E123F66-A8C3-4FCB-9F89-26C863553B59.jpeg Views:	0 Size:	213.8 KB ID:	146495
                        Head has pitting and needs flycut.
                        Block: clean up all gasket residual really good, then use Sharpie color the whole cylinder divider top, then gently sliding a flat granite on the surface to see if the Sharpie is rubbed off evenly.
                          Car is completely stock Obi, no tune on it.
                          Thank you for the feedback. Will do on the block, great help!
                            UPDATE:
                            The photo looks like the cylinder head is in fact damaged. Hard to tell how deep but your fingernail easily catches that black spot, no?
                              Hey. Glad to see we diagnosed correctly. You will want to take the head into your machine shop at the bare minimum. They should check it out and advise you for free. I would 100% get it check out by a professional as there isn’t much we can tell you from photos alone
                                I'd say you might as well still send out your fuel injectors or buy new ones when you reassemble everything for peace of mind.
