Pics of 245 and 275 tires on stock OEM 18s
    I ran 245/275 on close-to-stock size wheels for street class SCCA autocross until a couple years ago. 8" fronts and 9.5" rears. The tires looked meaty but not pinched. It honestly looked pretty normal when compared to what size tires manufacturers used to mount on wheels a couple decades ago. My old 1997 328is came with 225's on 7" wheels from the factory, which produced a similar look.
    It won't have that stretched sporty look but it will be fine.
      I run a very wide for a 275 tire (Falken RT-660) on a 17x9.5 wheel. Not quite what you asked for but it does show kinda what you’d be getting with the super meaty look.
        To each their own....but....especially the fronts. Gorgeous background BTW.
          In hindsight 17x10 would have worked better but I love how it drives.
            What is the motivation to run 245/275 on the oe wheels? You will have less responsive steering, the tires will be pounds heavier, and you’ll need to figure out what pressures to run to not make the ride and grip worse.
              Misinformation?
              Guy I ran square rear OE 18's with 265/35/18's all around and it was like the max size the wheels could handle. I could even feel the sidewalls flexing because it's just too much tire for the wheel.
              There were Hankook RS3's which I'll admit run a tad larger but not that far off from Michelins.
              If you wanna do it, go do it and report back.
              It will ride cushy and perform no better.
              If it's looks you're after, OE 18's ain't it big dawg.
              2005 BMW ///M3
              Black6MT Daily
                Du simply asked if anyone has pics haha.
                He didn’t ask for opinions, feedback or advice.
                  I hear a lot of people have been picking up the new the Auto Finesse Satin. I got to try it for the first time early this morning when I did a quick...
                  Bid for the chance to own a Chiaretto Red 2003 BMW M3 Coupe at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #29,777.
                  Bid for the chance to own a 2004 BMW M3 Coupe 6-Speed at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #19,744.
                  If we're talking about looks, these sizes on the 18" Style 67s make the car look pedestrian and less athletic, IMO. And if you enjoy precise handling, the stock sizes are probably better.
                  Just because it works, doesn't mean it's better.
                  2003 Imola Red M3 w/ SMG
                    Originally posted by 05Mdriver View Post
                    A bit surprised at the constant misinformation on this forum.
                    Both tirerack and manufacturer specs show that a 245 on a front 8 inch wide wheel and a 275 on a 9 inch wide is perfectly in spec.
                    Back to my original question - does anyone have pictures of a 245 and 275 on OEM 18s with stock suspension ?
                    Look up the stock sizes.
                    You generally want to stay as close to tirerack’s measured rim width as possible.
                    Not necessarily. It's just a standard for measuring purposes: https://www.tirerack.com/tires/tiret...jsp?techid=199
                    While we're at it: https://www.tirerack.com/tires/tiret...jsp?techid=198
                    Nobody is doubting that the 245/275 tires will fit on 18" Style 67s on a E46 M3.
                      Originally posted by K-Dawg View Post
                      https://detailingbliss.com/threads/a...gallery.23988/
                      That’s a nice piece of research on the pics. Thanks,
                      maw
                        Related question - anyone here go from stock 19 sizes - 225/40 255/35 - to 235/35 265/30 - and feel a noticeable change in ride? I'm considering but ride already firm, wondering how much lower aspect tires will affect. TIA.
                        Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
                          i'm running michelin PSS on 245/40-18 Front; 275/35-18 Rear but it's on the bilstein B12 pro kit which lowers it ~1".
                            Misinformation?
                            I run that in the rear and I love the feel of them more than 19s or other 18s. They are PS4s which are a bit stiff and I also have them at 48psi. That contributes to stiffness. I never ran RS3s but I can't imagine Hankook having a stiff tire.
                            The 18s do have a meatier look than 19s.
                              Ya think?! Glad I'm not your kidneys.
                                I have style 67s with 245/275. Bad picture but here.
