Originally posted by heinzboehmer
M-Track Mode
Originally posted by sina View Post
It starts around model year 2003, and extends through the end. Someone correct me if I'm wrong but I believe there is no exact month, ie. some early 03's may have it and others not.
There is a light in the cluster - in some cars its disabled and it can be enabled, in others it has to be retrofit. That arrow/cricle on the left. You can do the cluster test to see if you have it. And I believe if you do the cluster test and you do have the light that also means you have the MK60.
Originally posted by bimmer View Post
To clarify, you don't need to retrofit the light. If you don't have it, you code it so that single press brings up the center yellow circle/triangle with exclamation point (M Track Mode) and long press adds the "BRAKE" light to indicate that DSC is fully off.
d. If you don’t have a functional M-track symbol, and don’t want to solder the LED, set
“DTC_LAMPE” to “nicht_aktiv”
i. This will make the DSC system act like the non-M DSC where a single press
makes the DSC symbol light up, and a long press makes the DSC and Brake lights
turn on.
been running M-Track mode for a few months and curious on the rest of the settings. if you're running non-zhp brakes, you have to set DRUCKMODELL_HINTERACHSE” to “typ_2”
i presume it's because it assumes you're on non-zhp oem calipers so it's calibrating abs accordingly. what would this mean for someone who is running a BBK. it isn't ZHP, but it's bigger/strong than regular non-zhp calipers...so should we leave the value at "typ_3"?'06 Carbon Black
Sabelt, Brey Krause, MCS 2-way, SuperSprint, Karbonius, Epic, Volk
Originally posted by MarcoPolo View Postbeen running M-Track mode for a few months and curious on the rest of the settings. if you're running non-zhp brakes, you have to set DRUCKMODELL_HINTERACHSE” to “typ_2”
e.g. My brembos are slightly more front biased than stock, but my car is slightly front heavy shifting the bias rearward, so the non ZCP setting should be pretty perfect for my car.
A properly set up bbk shouldn’t feel “stronger”.
I have a 2003 (09/02 production) and it has the MK60 but my cluster doesn’t have the MDM light or even the symbol for it. Can I just buy a cluster from an 05/06 model and swap it out and have it work when i code track mode or is it not that simple? Does my cluster harness have the correct pins and wire for it etc?
Originally posted by Phoenix///M3 View PostExplanation from the last page of the DIY...
turn on.
*Disclaimer mine was custom coded in 2012-2013 and may have different programing.Last edited by old///MFanatic; 08-07-2020, 05:28 PM.6MT SLICKTOP - OE CSL Wheels - OE CSL Brakes - CSL Rack - CSL Trunk - CSL Diffuser - AA Tune - AA Pulleys- AS 40% SSK - 4.10 Motorsport Diff - Bilstein PSS9s - H&R Swaybars - CSL Lip - Gruppe M CF Intake - Supersprint - M Track Mode
Originally posted by S14 View PostMy only slight disappointment with M-track mode is that you can't use the fastest shifting parameters in SMG unless the DSG is fully disengaged.
Sine doing my SMG conversion a year ago I have somewhat forgot how to code.. But I do remember after doing the conversion I got all code happy and went through the thread on the old M3 forum and basically did everything on there (I LOVE the euro flashers for some reason)... I remember this being as easy as the rest obviously and found it to be my absolute favorite option I have turned on. I am an early-ish 03 as well, actually have a build date of 3/17/03 so I believe one of the very first facelift cars and it works flawlessly. I also use it as my preferred mode for normal driving
