Originally posted by ChapterM3
The plastic enclosure vibrates against the metal trunk. The electrical connector rattles and the two white plastic clips rattle.
The easy fix for the two plastic clips is to use a glue gun and secure them in place so they don’t vibrate. Zip Ty the electrical connector to stop it from rattling.
Once you do those two items turn on some music with some good bass and lay up inside the trunk (not fun btw) and check for rattles around the enclosure. I found my enclosure was vibrating on the back side. You can use something to shim it so it’s tight or remove the enclosure and add some additional padding in that area.
Good luck…
