Originally posted by Nate047
View Post
Steering wheel swap - can't get airbag to sit straight
Doesn't look like it has a p/n as it's part of the wheel assembly. A junkyard or ebay might be it..
No part number unfortunately. BMW includes it with the wheel. Stupid design. Best bet will be to salvage one from a spare 3 spoke round airbag wheel from a non-m e46, e39, or x5.Originally posted by Nate047 View Post
Yup same piece. Anyone know if these are available new? Part number?2003 E46 M3 TiAg/Cinnamon 6MT
2005 E46 330i ZHP Imola/Sand
Instagram:@thegenius46m
Don't mean to take this off topic too much but ever since I swapped steering wheels my new wheel tilts to the right slightly as compared to the last wheel which sat centered.
The last wheel as is the new wheel are aftermarket items, but of course they were both built around an OEM core.
My alignment is off and car does pull to the right and the vehicle is getting an alignment soon, should I re-posiotion my wheel so the 2 "tick marks" line up regardless off if that causes the wheel to lean to the right wheel driving straight?
Currently I have the new wheel with the tick mark one postion off of the tick mark on the column to compensate for the wheel not sitting correctly.
Any of you guys swapping wheels have any issues like this? It is strange as the splines in the wheel (and I assume the tick mark) are they same on every wheel, as in they should all be in the same location.2004 Silbergrau Metallic 6MT
Lol. I hoard them from the junkyard now if the airbag already has close to perfect fitment. The bracket does indeed bend on removal if you yank because its flimsy aluminum. Horrendous design imho. The only fool proof way to prevent this is three sets of hands. Two people to press on the clips at the same time while the other person pulls the airbag out evenly. Also be careful reinstalling the airbag as the newly recalled ones dent stupid easy above the roundel.Originally posted by Nate047 View PostYea I figured I would need to do that. Problem is you don't know for certain that it won't also bend as you remove it, or when whoever else removed it.2003 E46 M3 TiAg/Cinnamon 6MT
We have a 330ci and the local junkyard, having even a 3 series around here is a rarity. I want to pull some random wiring/connectors, I may be there this weekend.
If this wheel has the same bracket I may be able to take off the bracket, don't think they would charge much for that type of part.
I'll post back if I grab it.
Good call on the extra people helping. I might try that. BTW if you have an extra one that you know is not bent, I would gladly buy one from you for a handsome price my good sir.Originally posted by thegenius46m View Post
That will have the same bracket for sure. See if you can get it off without bending it! I definitely had to manhandle mine, one of the fasteners wouldn't come loose so I had to press the shit out of it from the back ti get it going, so in hindsight I'm not surprised it bent.Originally posted by Cubieman View PostWe have a 330ci and the local junkyard, having even a 3 series around here is a rarity. I want to pull some random wiring/connectors, I may be there this weekend.
Sorry, someone pulled the wheel already
If you have to yank, just assume the bracket is bent lol. Horrendous design.Originally posted by Nate047 View Post
If you can release both clips at the same time with an extra pair of hands you can avoid the problem on removal but it’s highly impractical
Sent from my iPhone using Tapatalk2003 E46 M3 TiAg/Cinnamon 6MT
but I will see if I can just bend my original one back. Still haven't gotten around to fixing this LOL.
