Originally posted by D-O
KW V3 vs. Stock Suspension Refresh for Street Driving
Turner’s or GC’s will work.Originally posted by D-O View PostAnyone know if there is a "street" camber plate that will work with the front TCK SA dampers? After perhaps going too far with my rear suspension I definitely don't want a harsh camber plate setup it the front. I looked and the Turners, but it looks like they will work only with dampers designed to work with the stock upper mount.
Depends what streets you're driving on. In Houston, 700 rear is jarring. In Austin, may be a different story, depending on what part of town you frequent.Originally posted by SQ13 View PostI’ll try the 400/700 setup before deciding if I want to go softer in the rear. The car will still have sort of a street/track setup and will retain all of the monoball parts (for now). I think Obi used 375+350/700+675, and if he felt that the car rode great and was compliant on the street, I’m sure I’ll be happy, too.
resurfacing this as I asked this question to TCK. he said they won't work, not sure if he's mistaken. he mentioned to use non-M camber plates. hard to get info via email and they don't answer their phoneOriginally posted by Obioban View Post
Is the tck 14mm (versus typical 16mm)?
Will Turner or GC not include a bearing (14mm i.d. to 16mm o.d.)?
I use a bearing in order to put my 14mm MCS into tns street plates. Vorshlag includes the bearing I know for a fact.
It sounds to me like non M is 14mm then.
I'm not sure about height being an issue, I don't see how it could be.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Not sure! You're talking about the sleeve correct? I assume GC can provide it. Come to think of it I'll bet they're a better place to ask than TCK. I'll try em on MonOriginally posted by Tbonem3 View PostIs the tck 14mm (versus typical 16mm)?
