Cliff Notes besides don't lower your car? 🍿
PSA: Think twice before lowering your car
It was my example to explain that weight is transferred in a vehicle with no suspension or body roll. I stand by my statement that body roll is not a characteristic to concern yourself with when discussing weight transfer, which was what the other poster was worried about.Originally posted by Wernd View Post
First, it was your example. Second, I was simply stating a fact that body roll does in fact affect weight transfer. Your comments were eluding to the opposite
Body roll has nowt to do with weight transfer unless bottles of water are rolling back and forth.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Or don't understand physics?DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by freshprince2421 View PostCliff Notes besides don't lower your car? 🍿Stock Height + Stock Suspension = Decent all-around balance of performance/comfort/practicality, but looks dorkyOriginally posted by K_M3 View Post
Wondering this too
Stock Height + Aftermarket Suspension = Best all-around balance of performance/comfort/practicality, but looks dorky
Lowered + Stock Suspension = Trash performance/comfort/practicality, but looks sick
Lowered + Aftermarket Suspension = Can be good if done right (stiff springs, maybe offset suspension pivots) but often done wrong, biased towards performance while compromising comfort/practicality, and looks sick
- Likes 5
I wish I read this thread before hand. I have kw v2 coilovers with swift 560 lb linear springs in the front. When I was in the process of installing the coilovers the mechanic had asked me how much drop I want. I told him not much but definitely a little bit more than oem so it’ll look more sporty. Well that “sporty” look resulted in me being about 13.5 inches from the center of the wheel.Originally posted by cobra View Post
now because the kw coilovers are so much shorter than normal dampers, the best camber I am able to get even with ground control camber plates is -3 which is really not good for street use. The car drives amazing and had a great smooth yet firm ride but I am being told that only way to get more positive camber is by raising the car which means I need get a $180 alignment for the 3rd time if I do raise it 😭😭😭.
in hindsight, I wish I never played around with the height. I really just wanted a slightly dropped car with better handling after the coilovers that drove straight.
after reading the whole thread I do agree with OP. Dropping definitely looks cooler but made it a nightmare to align even with camber plates.
It happens. When you're talking with a mechanic about suspension upgrades you have to be super clear as to the outcome you expect with regards to height, comfort, performance, etc. Talking in generalities is a good way for the you said/he said type of situation you're experiencing.Originally posted by Leafsrule531 View Post
Which ground control camber plates did you install? For the E46, there are M and non-M camber plates and non-M plates on an M3 allow much more negative camber, which is why you might have the negative camber problem.Originally posted by Leafsrule531 View Post
There are a handful of options out there for strut mounts/camber plates, but not a whole lot of information on the details and differences. I’m mostly concerned with streetable, quiet options with some sort of isolation. I wanted to see the differences up close and figured I would share the info. Hopefully this makes sense.
You can run non-M plates and get a significant increase in negative camber. Perfect for track, probably too much for street driving.
I was looking at another post from him and he has the GC race plates, I'm guessing that is contributing to his problem.Originally posted by Slideways View PostWhich ground control camber plates did you install? For the E46, there are M and non-M camber plates and non-M plates on an M3 allow much more negative camber, which is why you might have the negative camber problem.
Last edited by oceansize; 07-24-2024, 04:25 PM.2003 | 3.91 | CMP Subframe & RTAB Bushings | SMG (Relocated & Rebuilt) | ESS Gen 3 Supercharger | Redish | Beisan | GC Coilovers & ARCAs | Imola Interior | RE Rasp | RE Diablo | Storm Motorwerks Paddles | Will ZCPM3 Shift Knob | Apex ARC-8 19x9, 19x9.5 | Sony XAV-AX5000 | BAVSOUND | CSL & 255 SMG Upgrades | Tiag | Vert w/Hardtop
KW V2s with race plates? Assumed those would usually be paired with street platesOriginally posted by oceansize View Post
I said the same thing in that other thread -- he said they are "def for the M3" because he bought them (used) from a member of this forum. Whether or not that person had the right setup in the first place....Last edited by elbert; 07-24-2024, 06:21 PM.
