Tools for bushings?
    Tools for bushings?
    I'm going to DIY a full suspension refresh soon and was curious if anyone had a complete list of bushing pullers/press tools required? Thinking of picking up what I can at Harbor freight with their 4th of July coupon.
    Thank you
    It is probably a better idea to buy tools designed for the car. I am not familiar with what generic things would work from Harbor Freight, but I can recommend this Bav Auto kit. It will make all six bushings on the trailing arm very easy. I think there is a cheaper version on Amazon somewhere, but I cannot vouch for the quality.
    This is to line up the RTAB bracket, although you can use a ruler or make your own.
    If you do the struts, you need a spring compressor. I have found this to be safe and effective.
    For control arm bushings, I hammer them on with a socket. Might be a good idea to buy the right tool. I cannot help you with the subframe.
      Thank you
      FCAB bushing tool:
      CTA Tools 8920 BMW Control Arm... https://www.amazon.com/dp/B00VX0SXSC...p_mob_ap_share
        Lots of curse words...you'll need those.
        Subframe bushings will be the worst ones IMO - wonder what the best toolkit for that would be?
          It's so nice to be able to have a shop do these one time with solids and be done with it forever.
          I don't envy you diy guys.
            For the FCABs, any old three jaw puller will get them off. Using dish soap to lubricate on install will make it much easier. To the point where you can practically just push them on by hand.
              This was not my experience at all. Hence the tool above.
                Huh, I've done it a few times and the soap made it super easy, but good to know. The tool is probably good to have around.
                  Same here. Dish soap made it easy.
                    FCAB bushing tool:
                    This links to a RCAB tool, not FCAB. Is that the reason for struggle getting them on compared to other's experiences?
                    "CTA Tools 8920 BMW Rear Control Arm Bushing Kit is high quality, precision-engineered..."
                      This tool is amazing for the rear subframe bushings. It’s exactly what you want. It’s what BMW uses.
                      https://www.desertcart.com.om/amp/pr...5-3-series-z-4
                      several guys rent them on other forums. Just Google it with the part number.
                      with the subframe it took me 10 minutes per bushing. It was downright civilized! Lovely experience actually. The tool is super cool to use.
                      I think you can actually use it to remove the bushings with the subframe in the car, as long as you replace with solid or poly. But don’t quote me on that. That’s the way the techs do it.
                        Subframe bushings: 2-jaw puller and a torch. Use the puller to push the bushings out from the top after heating the subframe with the torch. No need to get red hot or anything, just enough to soften the rubber.
                          A couple videos my buddy took last weekend when I was doing some bushing replacement on my wifes E46, I just loaded them so the HD version is still processing.
                          Certainly not hard if you have the right tools and/or experience. Here I don't have the "right" tools, but I've done dozens and dozens enough to make it work. Also my portable hydraulic ram makes it easy once I get the cups, shims and sockets setup correctly.
                          Sub bushing removal:
                          Sub bushing install:
                          https://youtu.be/PmQIv4tsAlY
                          Trailing arm bushing removal (not RTAB):
                          Trailing arm bushing install (in this case we replaced with ball joints, Non-M car):
                          Email to [email protected]
                            For some reason the install video link isn't working when I click it in the original post so if not try this one:
                              Amazon description is wrong. Its for FCAB. I’ve used it half a dozen times on several BMW e46 models
