the 7/16" tubing worked great. i did the passenger side but the glass doesnt seal against the new weatherstripping. I even loosened the glass bolts and moved it around and just can't seem to get a 100% water tight seal. anyone else have this issue? in this pic you can see the buldge created in the weatherstripping by the inner 7/16 tube... maybe i should have pushed it in further?
Originally posted by Maxima SE View Postthe 7/16" tubing worked great. i did the passenger side but the glass doesnt seal against the new weatherstripping. I even loosened the glass bolts and moved it around and just can't seem to get a 100% water tight seal. anyone else have this issue? in this pic you can see the buldge created in the weatherstripping by the inner 7/16 tube... maybe i should have pushed it in further?
Originally posted by Turd_Ferguson View PostThanks for the outstanding thread. Been searching for this for my ZHP and don't want to spend $1K on parts when I've got other stuff to do.
Question: the guys that are putting the 7/16 OD tubing in, are you leaving it in to hold the shape or removing it once its in place?
Thanks!2004 Silbergrau Metallic 6MT
Leaving it in place.
If I'm reading through this properly, a list of materials needed:
--Lower Rail Left/Right:
https://www.fcpeuro.com/products/bmw...ck-51367891912
https://www.fcpeuro.com/products/bmw...ck-51367891911
--Metro Weatherstripping:
Free Shipping - Metro Moulded SUPERsoft Adhesive-Backed Weatherstripping Seals with qualifying orders of $109. Shop Weatherstrip Seals, Individual Position at Summit Racing.
--or--
3M NOS stripping if you can find it. I searched but couldn't locate.
--7/16" OD vacuum line x about 8 feet for both sides from your local hardware store
--Dry silicon lubricant- https://www.amazon.com/08897-Silicon.../dp/B000PJED72
--3M adhesive remover- https://www.amazon.com/3M-General-Pu...xpY2s9dHJ1ZQ==
--Plastic razor blade/scraper: https://www.amazon.com/Plastic-Scrap...NsaWNrPXRydWU=
Am I missing anything here?
Thanks. That's what I suspected but wanted to confirm before I jumped in.
--or--
i would also buy one of these for when you take off the gasket railing. it will make taking off the 3M tape much easier.
2007 Imola Red Z4M Coupe
--or--
i think those gloss black gasket railings are for non M3. the M3 ones are matte and $35.
https://www.amazon.com/ABN-Rubber-Er...9951708&sr=8-4
My understanding is the Shadowline trim is the same for the M3 as the ZHP, and in the OEM catalogs listed as "glanzschwarz" but I could be wrong. Any idea?
I'm in the middle of replacing the weatherstripping - can someone take a look at these pictures and tell me if I've done it right? I'm waiting on the quarter window horizontal trim, so I haven't attempted reinstalling the side finishers yet. My weatherstripping didn't kink and I didn't use any plastic tubing. I've been reading comments about getting a perfect "bulge" with the tubing, so at this point I'm wondering if this will fit or seal right since I didn't use any. I did trim the spine around the screw holes everywhere except the last two screw holes where the rail is. Does this sound right?
Originally posted by 6MTGirl View PostThis is the AmeriSeal multi-purpose bulb seal. I did heat it up for a few minutes with a blowdryer beforehand. It seems to fit really awkward around the rail at the end, but I don't know if I can get it to sit any flusher without damaging the rubber.
