S54 Dyno Database
  • ///MBan
    Car: Australian (right hand drive, Euro-spec) E86 Z4M Coupe, 28,000km for 'stage 1' and 40,000km by the time I got to ‘stage 3’.
    Chart 1: stock versus ‘stage 1’ of Supersprint V1 stepped headers and cat’d s-pipe and a tune by Severn which included data logging on the street and multiple revisions (this is the sixth iteration of the tune). Note that the V1 headers do not clear the steering shaft for RHD cars, so the workshop modified them to fit. Not sure how much worse they are after modification, but they did still make more power high in the rev range than the already very nice Euro-spec headers, even without a tune.
    More description here:
    https://www.zpost.com/forums/showthread.php?t=1816109
    Click image for larger version  Name:	2021 Mar - stock vs headers and tune 6_SML.jpg Views:	0 Size:	204.2 KB ID:	267499
    Chart 2: re-baseline dyno of stage 1 vs ‘stage 2’, which was the addition of SS x-pipe, Powerloop mufflers and an Eventuri intake. No re-tune for stage 2.
    More description here:​
    https://www.zpost.com/forums/showthread.php?t=1868864
    Click image for larger version  Name:	2021 Jun - Header tune 6 vs full exhaust intake and T6_SML.jpg Views:	0 Size:	145.5 KB ID:	267500
    Chart 3: re-baseline of stage 2 but with the SS x-pipe removed (the rasp and drone were too much for me), the addition of the Karbonius OE style plenum and heavier wheels (BBS RG-Rs, which are about 1kg heavier each than the Advans I had on for the previous dyno runs) versus Karbonius CSL ‘race’ intake and Severn alpha-n tune based on quite a lot of data logging on the street and fine-tuning on the dyno (exhaust mods the same as stage 2).
    I changed dynos for these runs simply because it was closer to where I live. Also, I had to superimpose the revs x-axis from a different chart, so it looks a bit funny.
    https://www.zpost.com/forums/showthread.php?t=2100583
    Click image for larger version  Name:	CSL intake vs SS exhaust Eventuri and Karb plenum - Apr 2024.jpg Views:	0 Size:	189.1 KB ID:	267501
    Adding it all up results in about 17% power gain versus stock – see the summary table below. I have to say I’m tempted to do a cam upgrade but the cost is really high and I haven’t found any dyno charts showing the change just from 280/272 camshafts (happy to be corrected if someone can point me in the right direction). I have seen a dyno for 288/280 cams, but the gains were only from around 6,800rpm and I would really want power and torque increases lower than that or I would never notice.​ I'd love to see a dyno chart showing the change from 280/272 cams alone if anyone has one to share.
    Click image for larger version  Name:	Power gains table.jpg Views:	0 Size:	73.3 KB ID:	267502
  • StrangeC
    Looking for feedback on this run:
    • Trace looks lumpy 4500-5500 vs other smooth traces here, but car seems to run fine.
    • Power tapers off at 7000RPM
    I always felt Kassel 'phoned it in' during the remote dyno tuning. I was renting dyno time and Kassel took a loooong time between runs to get back to the tuner because they were busy with other customers...which got.. expensive. Does this all look normal to you?
    S54
    Rebuilt S54 in E36 chassis
    Cat 280/272 cams
    Stepped headers
    E46 Section 2 w added resonator mid pipe
    E46 Section 3 with Borla thru X muffler exhaust
    Z3 Airbox
    Click image for larger version  Name:	M3 S54 Mustang Dyno RS.jpg Views:	0 Size:	87.2 KB ID:	260339
    Thanks.
  • davidinnyc
    Nice. I'll be running close to the same setup except a full SS 63.5MM headers-to-exhaust (Dinan Section 3). Excited to see how it performs before cams.
  • marksae
    2004 E46 M3 - 169k miles
    Karbonius CSL airbox w/ carbon snorkel (Stock CSL IAT in original location)
    Euro Headers and Section 1
    Supersprint Race Section 3
    Kassel Performance MSS54HP Full CSL hardware/firmware conversion
    Kassel Performance ECU tune
    Kassel Performance MAP sensor kit
    91 octane
    Recent Maintenance:
    Rebuilt VANOS w/ Beisan exhaust hub
    Rod bearings replaced with ACL bearings
    New o2 sensors and spark plugs
    345whp, 271wtq - Mustang Dyno
    Click image for larger version  Name:	dyno_stance.jpg Views:	0 Size:	208.1 KB ID:	258584
    Click image for larger version  Name:	dynoplot2.jpg Views:	0 Size:	125.9 KB ID:	258585
  • gashby
    03 e46 m3
    112k miles/ roughly 20k on new block
    HPF turbo
    mods besides that unknown
    currently looking at ecus/tunes because car is running rough
    Cant find anyone to tune the AEM ecu
  • bigjae46
    Nice! I was expecting a fireball to shoot out the exhaust
    How many miles on the engine?
    About 101k miles on the motor, not the original. 8k old plugs, sensors, and stuff. Only thing relatively new are the cam sensors.
    It used with the Evolve tune and the Martyn ECU tool but I think the PCS tune eliminated that.
  • Slideways
    Click image for larger version Name:	James Allison Dyno Graph.png Views:	0 Size:	45.4 KB ID:	250879 325whp/257tq
    Megan headers (swaintech coated)
    BW race with straight section 2
    Injen intake
    Paul Claude tune
    I’m really surprised, was expecting lower. This kicks me out of NASA TT4. This actually kind of screws me because I setup the car with ballast. Now I need to un-setup the car.
    Probably can get more since the car was on the edge of overheating.
  • bigjae46
    Injen intake
    Paul Claude tune
  • EthanolTurbo
    How did the dyno session go?
    Badly. Wasn't able to get any good charts because had a spark issue and the car misfired on the dyno. Went home and put in new coils and plugs, car runs super strong and smooth. HTE says the tune is done and no need to touch it up so I guess I have to schedule another hour of dyno time if we want meaningful numbers.
    Honestly, I am pretty disappointed and this is why I told someone else in another thread to ALWAYS do coils and plugs before a dyno day/tune. I would like to go back but feel like HTE should continue tuning it. Anri said that perhaps HTE loaded up a full power tune and it's at 100%.
    I also would like to Dragy the car and get 60-130 info + 1/4 mile trap speed to see where it's at.
  • duracellttu
    Dyno day tomorrow. This build has taken me over a year and a half since my last dyno. Feels like forever.
    Here's what I did to prepare:
    New o2 sensors
    Full valve job
    ICV cleaned
    Crossing my fingers for good results and more power over the street tune we just did. Car feels really good, feels as fast or faster than my E90 M3 slicktop with lightweight wheels, intake, exhaust and E85 tune (cats still on it). Should be coldish too, 50-60F.
  • OldRanger
    Hopped on the dyno for some tuning. 2005 with 167K or so on the clock. Every engine sensor, VANOS rebuild, Valve adjustment, fuel pump, filter and regulator over the past year or so. New OE coils and plugs and upstream O2s were the final touch.
    • Turner CSL Style Intake with IAT in plenum
    • Megan Racing Headers
    • OEM Section 1 and 2
    • SS Race Muffler
    • Epic
    • 93 Octane
    • OEM 19’s and 3.62 gears
    Weather was 28F and dry. So cold, we didn’t want to deal with fans adding air pressure at the intake.
    SAE smoothing: 313hp @ 8,200; torque was 243 at 5,200
    Driveability is as good or better than stock, even partial throttle.
  • BMWfanz
    New o2 sensors
    Full valve job
    ICV cleaned
    spec?
  • EthanolTurbo
    New o2 sensors
    Full valve job
    ICV cleaned
  • bimmerfan08
    Originally posted by ZHLPR View Post
    30 HP from headers and a tune is solid. Just picked up a set of Megans.
    Indeed. For ~$800, these motors can pick up ~11% more HP. On a dollar/HP basis, catless headers and a tune are probably the most cost-efficient mods for increasing power.
  • ZHLPR
    Originally posted by bimmerfan08 View Post
    I think I previously posted these files on M3forum but don't see my dyno graphs on this forum.
    Stock motor on 7-19-2019. This was my baseline. Mileage: 164,439.
Name:	2019-7-19 E46 M3 Stock Dyno.png
    Modified motor on 7-10-20. Mods include Megan catless headers, 200 cell cats, and an HTE tune. Mileage: 167,202.
Name:	2020-7-10 E46 M3 Headers + Cats Dyno.png
