Originally posted by Cubieman
View Post
Turner Motorsport CSL Airbox
You just want to compare it to your karb lol06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
Budget CSL MAP Conversion
Yea, I'll take it out of the box to inspect it out of curiosity, take a ton of photos then back in box it goes to be sold.Originally posted by COVID-19 View Post
BTW I currently have 3 people wanting it, so folks can PM me about it to "get in line" but I've decided since enough people have contacted me I want to sell the intake along with the parts kit (breather/shutoff) and possibly the OEM Filter that i have coming with the box..
Haven't made up my mind on the filter, have an ITG in the Karb. but I'm a sucker for factory and I LOVE hoarding parts!!Last edited by Cubieman; 05-16-2020, 12:03 AM.2004 Silbergrau Metallic 6MT
- Likes 2
Nice, thanks for the info, that is great news! I assume you ordered directly from Turner?Originally posted by F360C View PostMy box just shipped today! There are new pics of a production box on Turners website... looks like the weave matches between the two halves of the box2004 Silbergrau Metallic 6MT
Box does look good! Now we need some info on fitment!Originally posted by F360C View PostMy box just shipped today! There are new pics of a production box on Turners website... looks like the weave matches between the two halves of the box06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
newb here. bought the car late last year and i was reading up on the CSL airbox when m3f went under. could someone educate me a little bit. i had read that buying the airbox was "just the beginning". apparently, there are more parts to order to complete the setup? is this more of an aesthetic need or do you really NEED more parts in order to install the TMS CSL Box. Can this not be a plug and play system? i'm currently running an Epic tune so i only imagine they have a CSL tune. just seems this may or may not be worth the trouble but curious on what everyone else feels.
appreciate any info anyone can provide.'06 Carbon Black
Sabelt, Brey Krause, MCS 2-way, SuperSprint, Karbonius, Epic, Volk
You absolutely need more parts, no matter how you slice it. To properly run a CSL airbox you need a few different vacuum tubes that are of different lengths than those that would connect to the stock airbox, as well as an intake air temp sensor. But more importantly, you at least need to delete the MAF, as it's incompatible with a CSL airbox. You have choices in how you do that: the one requiring the least parts is you could simply just delete the MAF and run an alpha-n tune which just makes assumptions about airflow based on temperature and engine load instead of having a sensor that actually measures it. The better way to do it (and how a real CSL runs) is to retrofit a MAP sensor to replace the MAF sensor. There are many choices for how to retrofit a MAP sensor, each with their own associated parts and costs. Finally, if your car is pre-2003, you would need to upgrade your DME, as older DMEs (MSS54) can't run MAP based tunes, only the later DME models (MSS54HP) can.Originally posted by MarcoPolo View Postnewb here. bought the car late last year and i was reading up on the CSL airbox when m3f went under. could someone educate me a little bit. i had read that buying the airbox was "just the beginning". apparently, there are more parts to order to complete the setup? is this more of an aesthetic need or do you really NEED more parts in order to install the TMS CSL Box. Can this not be a plug and play system? i'm currently running an Epic tune so i only imagine they have a CSL tune. just seems this may or may not be worth the trouble but curious on what everyone else feels.
Also need to buy a special filter.
Most people say it's worth the cost/trouble, but I can't comment since I don't have mine yet/Last edited by ATB88; 05-17-2020, 12:58 PM.
Nice explanation ATB, you definitely want to go the MAP route in my opinion if you are already dropping this kind of $ for a mod.Originally posted by ATB88 View Post
Some parts you can reuse like your Breather Tube and Shutoff Valve but they require modifying, I simply bought the CSL parts. You will also need to bend you dipstick tube or buy the shorter CSL dipstick/dipstick tube, but if you run the CSL dipstick you have remove part of the airbox everytime you want to check your oil so most just bend their tube.
I should note you can (if running CSL software) check your oil level on your dash, but that will require additional coding and I personally like to check my oil the old fashioned way.
Also I used the Turner IAT relocation harness so I didn't end up having to cut off/splice into my MAF wiring. Since the Turner box won't take a flap you don't need to worry about wiring for that. Also if you run the MAP sensor and use factory terminations on the wiring that plug directly into the DME connector block and you use Turner harness you will only be splicing one wire!Last edited by Cubieman; 05-17-2020, 01:25 PM.2004 Silbergrau Metallic 6MT
By your signature I’m guessing you have an 06.Originally posted by MarcoPolo View Postnewb here. bought the car late last year and i was reading up on the CSL airbox when m3f went under. could someone educate me a little bit. i had read that buying the airbox was "just the beginning". apparently, there are more parts to order to complete the setup? is this more of an aesthetic need or do you really NEED more parts in order to install the TMS CSL Box. Can this not be a plug and play system? i'm currently running an Epic tune so i only imagine they have a CSL tune. just seems this may or may not be worth the trouble but curious on what everyone else feels.
Besides the airbox. You will need the IAT sensor and connector - air filter -TB boots (could get them used from an pre 04 intake) - you can modify both the breather hose and the air shutoff valve and still have clean install - Tune - if you go alpha n that’s all you need, but if you go with a MAP then you will need a MAP kit - last would be to turn/bend the dipstick tube06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
guess my email notification was reset again. gotta love it! anyway, yes i have an '06. if i were to do, i would most certainly go for a MAP kit. i did do the IAT relocation on my oem setup so i imagine that's the same thing? i would simply unplug the maf and cap/cover it up? sucks about the dipstick. i track the car and i do check oil often on track days so that would seem frustrating. otherwise, it doesn't seem that challenging to fully install. fwiw, i do have an MSS54HP so i'm clear on that. appreciate the info. i didn't get in on the GB but it'll be something i'll keep an eye. i also happen to have an AFE Stage 2 that i bought awhile ago but never installed. it's worth giving it a shot just to buy time until more reviews of the TMS box come in.
thanks for everyones feedback.'06 Carbon Black
TMS uses the Hella IAT sensor, uses the same connectors as other relocation kits. The dipstick still works you just have to move it towards the strut tower06 ZCP SMG | HTE CSL MAP QuaranTune | SL CSL Airbox | Eventuri Scoop | DMG Strut Bar | RE El Diablo | CPI Euro200R | AP Headers | Porsche BBK | ST XTA | TMS 3-Pulleys/F-Sway/Mono FCAB | AKG Trans/diff/Subframe/RTAB | SPL RCA | SGT SCZA Trunk | ACL | Beisan | Redish | AFD E85 |
