Vanos Rebuild Start Hesitation
    Originally posted by jamesfoley View Post
    Will check the grounds, getting to the starter to just check the cables is a bit of a pain. .
    It's not too bad at all. Jack the left front up, drop the left LCAB lollipop down to give some space, then laydown and reach up to make sure the 13mm nut on the cable is not loose (disconnect batt or the big black cable off the jumper post first).
      Oh a side note, is this the proper way to change out the starter too?
        That is done by removing the intake manifold which is fairly easy.
          Oh a side side note, what tool do people use to take off the hose clamps and not break them? Is there a special bmw tool? Couldn’t find one and just saw that people use hooked pliers
            A good pair of needle nose pliers with the jaws that have those small teeth works and it's a tool that most people have in their tool box. The actual tool is probably something like this - Clamp Plier For Oetiker - https://www.zoro.com/beta-clamp-plier-for-oetiker-14730020/i/G1903637/?utm_source=google&utm_medium=surfaces&utm_campaig n=shopping%20feed&utm_content=free%20google%20shop ping%20clicks&campaignid=19717005309&productid=G19 03637&v=&gad_source=1&gclid=EAIaIQobChMIkZSRmtHthQ MVkwOtBh1p7ACbEAQYASABEgKKH_D_BwE&gclsrc=aw.ds
              That sounds like more work than just taking off the intake manifold
                Thought the same, but the intake clamps are also a pain in the arse.
                Does the positive from the battery go straight to the point in the engine bay to feed the whole car?
                Noticed that my wing mirrors were slow to fold again even though voltage is good.
                  They're not that bad once you get the hang of them. Medium sized needle nose pliers (long enough to reach the clamps, but not so big that they can't squeeze through things to reach) are your friend.
                  No, it goes battery -> BST -> fuse box -> terminal by the hood switch -> starter -> alternator
                    I use one of these
                    Click image for larger version  Name:	image.png Views:	0 Size:	246.5 KB ID:	263489
                    Wasn't really the getting them unclipped that was the problem, its that they stick to the rubber coupler and require some persuasion to free up, at which point they get kind of mangled and need to be replaced. Do wish they were just thinner screw style hose clamps. ​
                    Looks like it splits into two from the positive terminal at the battery. Smaller cable feeds fuse box and is bundled in a larger loom, chunky cable is protected by the pyro fuse and goes through the car and through the firewall to the jump post under the bonnet. Being a UK car my fuse box is on the other side, so I guess the loom for the fuse box just goes through the dash.
                    All terminals look fine up to the jump post in the bonnet. Will try and find some time to pull the manifold off and check under there.
                    What is frustrating is I jumped in the car this morning after it sat overnight and it starts up perfectly fine https://www.youtube.com/watch?v=kWFITtBoRDw
                    I feel like it'd actually be easier to solve if it just hesitated every time. I need to try and catch the hesitation on video.
                    The VANOS just not functioning correctly after being rebuilt initially still plays on my mind, but I have no idea what I can realistically test other than running the DIS VANOS test. Honestly just feels like cam position is wrong sometimes until enough oil pressure is made to move them, kind of as if the accumulator isn't holding pressure, or the VANOS isn't returning to the correct position every time when the engine is turned off.
                      for vanos, all you can do is to check the timing and do the DIS test.
                        Anyone able to shed some light on what happens to the VANOS when the car is started and the car is turned off?
                        From what I've read it should be in the "default" position for next start, which is intake fully retarded and exhaust fully advanced. Does this happen when the engine is switched off? If so, where does the oil pressure come from to do this (oil pump / accumulator)?
                        Looking back at my post where I log VANOS intake actual vs DME commanded on a rough start you can see that it doesn't start in the same spot the DME is commanding, which makes me think its not always reaching the default position when switched off (https://nam3forum.com/forums/forum/m...060#post208060)
                        Is it at all possible I'm losing oil pressure within the VANOS that is either causing the exhaust or intake pistons to shift, or for them to not reach the default positions when turned off?
                          During cranking, slow rpm, so I think it's best to advance both IN and EX cams to maximized chamber fill as no reason to retard the IN valve closing at low rpm. You gain more power at high rpm with more retard IN valves because the intake gas still flowing in at high speed. But I don't know if the vanos system can move the IN cam from max retard to max advance during engine shut down.
                            Pulled from the reference manual it says:
                            The “default” mechanical stop position without VANOS influence is:
                            Intake Camshaft = Retarded (130º spread angle)
                            Exhaust Camshaft = Advance (83º spread angle)
                            The volume of pressurized oil is stored in the accumulator supplying both adjustment pistons. Both pistons are held in the default position by the high pressure oil.
                            S54B32 intake cam spread is 70º to 130º, so 130º would be fully retarded, and exhaust cam spread is 83º to 128º, so 83º would be fully advanced.
                            So I'm assuming this is the default position it goes back to, and the accumulator holds the pistons there. But I'm not sure the accumulator was designed to hold pressure indefinitely, videos of pressure tests show it does slowly bleed off. S62 actually has a shut off valve on the accumulator to hold pressure for the next start, but looks like that might just be to remove rattles.
                            Just interested to know if the VANOS is supposed to assume the default position when the engine is switched off, or if it is supposed to quickly move to that position when switched on using store accumulator pressure.
                            I honestly think there is something wrong with the VANOS somewhere, but its not hugely complicated, high pressure oil goes in and pistons move back and fourth. With it working and passing tests I don't really know what the issue could be other than it potentially not holding the position it expects when being started.
                            Even though its had new piston seals, could these be damaged causing a pressure loss? Should bad seals present themselves as a problem consistently, rather than the intermittent issue I have? Could the oil pump disc be bleeding pressure, or not building enough pressure? Is the accumulator not holding any pressure so it can't make adjustments and engine start / stop?
                            Determined to find the cause of this but do feel I'm clutching at straws a little now.
                              It can't assume stored pressure at crank time. That could be hours/days/weeks/months. The accumulator is only for short term "pressure storage".
                              It sets it at engine shutdown as I understand it, but I can't find any specifc mention of that in the BMW training documents.
                              Without any high pressure do the cams naturally set themselves from cranking i.e. to the "default mechanical stop"
                                It sets it at engine shutdown as I understand it, but I can't find any specifc mention of that in the BMW training documents.​
                                I agree, that makes sense, but I equally can't find any reference to how this is meant to work.
                                This is another thing I can't find any info on. Diagrams just show that the piston is moved via oil pressure difference either side of the piston, I don't know if there is anything physically mechanical that returns these pistons to their default on shutdown which is why I sort of assumed accumulator pressure was used here when the engine isn't running. Like, what would happen if I unplugged the solenoid pack and ran without VANOS, other than be unhappy that it can't move the cams.
                                It's almost like the oil pressure that is there isn't always enough to get the pistons in the right place, maybe because the accumulator doesn't hold pressure anymore, or the new seals are stiff and the (potentially non-existent) pressure the accumulator has can't move them quick enough / far enough when the engine is turned off.
