Originally posted by jamesfoley
Vanos Rebuild Start Hesitation
It's not too bad at all. Jack the left front up, drop the left LCAB lollipop down to give some space, then laydown and reach up to make sure the 13mm nut on the cable is not loose (disconnect batt or the big black cable off the jumper post first).
That is done by removing the intake manifold which is fairly easy.
Originally posted by jpy1980 View Post
Oh a side side note, what tool do people use to take off the hose clamps and not break them? Is there a special bmw tool? Couldn’t find one and just saw that people use hooked pliers
It's not too bad at all. Jack the left front up, drop the left LCAB lollipop down to give some space, then laydown and reach up to make sure the 13mm nut on the cable is not loose (disconnect batt or the big black cable off the jumper post first).2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
That sounds like more work than just taking off the intake manifold
Does the positive from the battery go straight to the point in the engine bay to feed the whole car?
Noticed that my wing mirrors were slow to fold again even though voltage is good.
Originally posted by jamesfoley View PostThought the same, but the intake clamps are also a pain in the arse.
Originally posted by jamesfoley View PostDoes the positive from the battery go straight to the point in the engine bay to feed the whole car?
No, it goes battery -> BST -> fuse box -> terminal by the hood switch -> starter -> alternator2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - MSS54HP Conversion - Kassel MAP - SSV1 - HJS - PCS Tune - Beisan - MK60 Swap - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
Originally posted by heinzboehmer View PostThey're not that bad once you get the hang of them. Medium sized needle nose pliers (long enough to reach the clamps, but not so big that they can't squeeze through things to reach) are your friend.
Wasn't really the getting them unclipped that was the problem, its that they stick to the rubber coupler and require some persuasion to free up, at which point they get kind of mangled and need to be replaced. Do wish they were just thinner screw style hose clamps.
Originally posted by heinzboehmer View PostNo, it goes battery -> BST -> fuse box -> terminal by the hood switch -> starter -> alternator
All terminals look fine up to the jump post in the bonnet. Will try and find some time to pull the manifold off and check under there.
What is frustrating is I jumped in the car this morning after it sat overnight and it starts up perfectly fine https://www.youtube.com/watch?v=kWFITtBoRDw
I feel like it'd actually be easier to solve if it just hesitated every time. I need to try and catch the hesitation on video.
The VANOS just not functioning correctly after being rebuilt initially still plays on my mind, but I have no idea what I can realistically test other than running the DIS VANOS test. Honestly just feels like cam position is wrong sometimes until enough oil pressure is made to move them, kind of as if the accumulator isn't holding pressure, or the VANOS isn't returning to the correct position every time when the engine is turned off.Last edited by jamesfoley; 05-02-2024, 05:21 AM.
Anyone able to shed some light on what happens to the VANOS when the car is started and the car is turned off?
From what I've read it should be in the "default" position for next start, which is intake fully retarded and exhaust fully advanced. Does this happen when the engine is switched off? If so, where does the oil pressure come from to do this (oil pump / accumulator)?
Looking back at my post where I log VANOS intake actual vs DME commanded on a rough start you can see that it doesn't start in the same spot the DME is commanding, which makes me think its not always reaching the default position when switched off (https://nam3forum.com/forums/forum/m...060#post208060)
Is it at all possible I'm losing oil pressure within the VANOS that is either causing the exhaust or intake pistons to shift, or for them to not reach the default positions when turned off?
Originally posted by jamesfoley View PostAnyone able to shed some light on what happens to the VANOS when the car is started and the car is turned off?
During cranking, slow rpm, so I think it's best to advance both IN and EX cams to maximized chamber fill as no reason to retard the IN valve closing at low rpm. You gain more power at high rpm with more retard IN valves because the intake gas still flowing in at high speed. But I don't know if the vanos system can move the IN cam from max retard to max advance during engine shut down.
The “default” mechanical stop position without VANOS influence is:
Intake Camshaft = Retarded (130º spread angle)
Exhaust Camshaft = Advance (83º spread angle)The volume of pressurized oil is stored in the accumulator supplying both adjustment pistons. Both pistons are held in the default position by the high pressure oil.
So I'm assuming this is the default position it goes back to, and the accumulator holds the pistons there. But I'm not sure the accumulator was designed to hold pressure indefinitely, videos of pressure tests show it does slowly bleed off. S62 actually has a shut off valve on the accumulator to hold pressure for the next start, but looks like that might just be to remove rattles.
Just interested to know if the VANOS is supposed to assume the default position when the engine is switched off, or if it is supposed to quickly move to that position when switched on using store accumulator pressure.
I honestly think there is something wrong with the VANOS somewhere, but its not hugely complicated, high pressure oil goes in and pistons move back and fourth. With it working and passing tests I don't really know what the issue could be other than it potentially not holding the position it expects when being started.
Even though its had new piston seals, could these be damaged causing a pressure loss? Should bad seals present themselves as a problem consistently, rather than the intermittent issue I have? Could the oil pump disc be bleeding pressure, or not building enough pressure? Is the accumulator not holding any pressure so it can't make adjustments and engine start / stop?
Determined to find the cause of this but do feel I'm clutching at straws a little now.
It can't assume stored pressure at crank time. That could be hours/days/weeks/months. The accumulator is only for short term "pressure storage".
It sets it at engine shutdown as I understand it, but I can't find any specifc mention of that in the BMW training documents.
Without any high pressure do the cams naturally set themselves from cranking i.e. to the "default mechanical stop"
Originally posted by Shonky View PostIt can't assume stored pressure at crank time. That could be hours/days/weeks/months. The accumulator is only for short term "pressure storage".
Originally posted by Shonky View PostWithout any high pressure do the cams naturally set themselves from cranking i.e. to the "default mechanical stop"
This is another thing I can't find any info on. Diagrams just show that the piston is moved via oil pressure difference either side of the piston, I don't know if there is anything physically mechanical that returns these pistons to their default on shutdown which is why I sort of assumed accumulator pressure was used here when the engine isn't running. Like, what would happen if I unplugged the solenoid pack and ran without VANOS, other than be unhappy that it can't move the cams.
It's almost like the oil pressure that is there isn't always enough to get the pistons in the right place, maybe because the accumulator doesn't hold pressure anymore, or the new seals are stiff and the (potentially non-existent) pressure the accumulator has can't move them quick enough / far enough when the engine is turned off.
