Camber/Caster Plates - Pros and Cons?
    You brought it up. Now please…do tell…what’s the issue with those welds?
    but…a pretty weld can be good, can also be bad. There are many variables to consider. Sometimes, a weld has to be ugly to prevent failure.
    What in God's straw man are you talking about? 😂
      If you need a reminder...
      Dafuq is goin on with those welds son.
        So the reinforcement plates don’t seem to fit the shape of my 01 M3’s strut towers. Is this a known issue?
        997.1 GT3 Carrara White/Black
        C43 AMG Diamond Silver/Red​
          Yes I think it's known. There are shims/spacers for the early strut towers for the top, but I don't know about the underside.
            SQ13 as mentioned in other thread, I don't think you have an issue and I'd line them up and see if they don't seat themselves. I'd bet you still have some stock top mounts you could use to test that theory
              False alarm y’all. I’m just dumb.
                Thats impressive, how many miles?
                *EDIT: Also, were you running a strut tower brace and if so, which one?
                Sorry for the late reply.
                I have almost 100k miles on the camber plates. About 80k of those are with the factory struts/springs and the rest on Ohlins R&T.
                I am running the factory strut bar on the car.
                  On my GC Street camber plates, I use thrust bearings between the spring perch/adjustment collar and the spring to avoid binding. iirc, the OE BMW thrust bearing stuck a bit when I was running them alone..
                  Do you happen to have any pictures of the setup? A PN on the trust bearings you used?
                  I would love to see what you have done and fix the noise on my camber plates, its driving me nuts.
                  Just in case it matters, I am also running a square wheel/tire set-up, but I doubt that matters at all.
                    I imagine these would work.
                    Improve your coilovers performance and reduce unwanted spring noise with Swift Thrust Sheets. These proprietary self lubricating sheets will allow your coilover springs to smoothly rotate around the perch under compression. This enables the load on the spring to be more evenly distributed easing the pre-load and reduci
                      R1pilot those thrust sheets that SQ13 linked will do the job. I went a little more complicated with roller thrust bearings from McMaster-Carr. The setup is one bearing with 2 washers for each spring. I used the thinnest washer.Click image for larger version
                      2007 GX470
                      build/journal
                      ig: @zzyzx85
                        Thank you. Now I need to measure the Ohlin spring diameter.
                        I wonder why this never happened with the stock springs/struts and the GC camber plates ... mechanically it should be the same?
                          I’m guessing you run the stock Ohlins springs up front? The lower part is 65 mm.
                            Maybe the lack of a "stop" on the bottom spring perch to keep the spring from twisting is the cause of the noise.
                            2007 GX470
                            build/journal
                            ig: @zzyzx85
                              Assuming you have replaced the BMW bearing? If not, you should also replace the bushings in the street plates. $100 for both of those from GC. I think it's odd you'd have any noise, I have never heard a peep out of mine running V3's, which has the progressive spring and stock perch as well.
                                That is good info, often time I hear people say my car has been together for X years and its fine, then find out they only drive it 1k miles a year, lol.
                                I wonder if the stock springs helped or the strut brace acted like a reinforcement?
                                Here are pics of:
                                BMW reinforcement plate
                                Stock Non-M mount
                                Stock M3 mount
                                GC Camber plate
                                Vorshlag Camber plate
                                TMS Camber plate
                                Email to [email protected]
